#11
David Megginson wrote in message ...
(Rocky) writes: A little trick that I learned back in the early 50's, and pass on to all who don't know of it, is using the PRIMER to keep the engine running if it shuts down for carb ice. The primer injects fuel directly into the intake manifold bypassing the carburetor and can keep the engine running intermittently and in many cases generate enough heat for the carb heat to become effective again. I've used this technique a few times in aircraft to get home. In Pipers (PA25 Pawnee while crop dusting) and Cessnas (C-172 and 177). Ol Shy & Bashful That's a brilliant suggestion -- I'm assuming that you leave carb heat on, so that there's still an air supply into the cylinders. All the best, David Carb heat is left on in the event that the generated engine heat becomes effective again to change the intake air temp. |
![]() Rocky wrote: A little trick that I learned back in the early 50's, and pass on to all who don't know of it, is using the PRIMER to keep the engine running if it shuts down for carb ice. The primer injects fuel directly into the intake manifold bypassing the carburetor and can keep the engine running intermittently and in many cases generate enough heat for the carb heat to become effective again. Since carb ice blocks the induction air, this is unlikely to work well. George Patterson The optimist feels that we live in the best of all possible worlds. The pessimist is afraid that he's correct. James Branch Cavel |
![]() David Megginson wrote: That's a brilliant suggestion -- I'm assuming that you leave carb heat on, so that there's still an air supply into the cylinders. Carb heat does not provide an alternate air supply to the cylinders. It bypasses the air filter, but the air still has to pass through the carb and the (blocked) butterfly valve. George Patterson The optimist feels that we live in the best of all possible worlds. The pessimist is afraid that he's correct. James Branch Cavel |
![]() "Rocky" wrote in message om... pamaway (Hobbes1157) wrote in message ... Hi there. I've got a question about the carb heat in a Cherokee. I was told that you only need to apply it for a short while (5 seconds) while on downwind to make sure the carb is clear of ice. She (CFI) said that Pipers don't need it all the time as Cessnas do. Is this just a technique or proper procedure? Comments appreciated. Plus: Hey Jay is this a family event at Oshkosh you're planning? I've got my non-flying family driving with me up to OSH and would like to meet some other local and non-local friendly folks! Thanks, Nolan PPSEL, INST, commerial student IA24 (green castle) Nolan For the lesser experienced pilots in particular, the use of carb heat can save you some anxious moments without unduly affecting the engine performance in the pattern. Of course you'll notice the loss of performance if you forget to turn carb heat OFF if you elect to make a take-off or go-around. Even then it isn't life threatening unless really adverse conditions exist. A little trick that I learned back in the early 50's, and pass on to all who don't know of it, is using the PRIMER to keep the engine running if it shuts down for carb ice. The primer injects fuel directly into the intake manifold bypassing the carburetor and can keep the engine running intermittently and in many cases generate enough heat for the carb heat to become effective again. I've used this technique a few times in aircraft to get home. In Pipers (PA25 Pawnee while crop dusting) and Cessnas (C-172 and 177). So you ignored the needs of the engine and gave so little consideration to the atmospheric conditions you let it quit through carb ice. Forgiveable once, we all make mistakes but you say you've done it a few times. I suggest you take up gliding (oops, sorry, you already have, in Cessnas, Pipers...) Rgds Andy R |
That's a brilliant suggestion -- I'm assuming that you leave carb heat on, so that there's still an air supply into the cylinders. Carb heat does not, in the engine installations I'm familiar with, provide an alternate supply of air to the engine cylinders. It provides an alternate supply which must still go through the carb venturi. If the carb venturi is sufficently blocked so as not to supply air/fuel in the proper ratio for combustion, it's not clear to me how injecting more fuel into the cylinders is likely to help. OTOH, the primer is worth trying because if the problem is really with the fuel supply, the primer is an independent fuel supply system and this might help. Might also help suck out a little more fuel from nearly-dry tanks -- have heard so anyway. A lot of times IMO people really don't know what the problem is, unless they have a "carb temp" probe. It's just assumed that carb ice is a likely cause of engine failure when the atmospheric conditions are right and there isn't anything found to be wrong w/ the engine at a later time. My $0.02 Sydney |
![]() Angus Davis wrote: The type of engine does not affect whether or not it will be susceptible to carb ice. Yes, it does. Lycoming routes the induction through the oil sump in many of their engines. Once the engine reaches operating temperature, that keeps the induction tubes at about 180 degrees. That keeps the carburetor much warmer than Continental engines do. George Patterson The optimist feels that we live in the best of all possible worlds. The pessimist is afraid that he's correct. James Branch Cavel |
Have you ever experienced carb ice with an injector carb? | flybynightkarmarepair | Home Built | 1 | January 31st 05 01:48 AM |
Induction System Water Problem | Mike Spera | Owning | 1 | January 30th 05 05:29 AM |
Carb heat specs? | Rich S. | Home Built | 2 | November 13th 04 04:39 PM |
alternate carb heat | Ray Toews | Home Built | 16 | October 29th 04 12:41 PM |
Carb heat shroud | Gene Seibel | Owning | 3 | January 27th 04 04:13 AM |
