"G.R. Patterson III" writes:
It's pretty simple, really. It doesn't matter at all if your altimeter is off by hundreds of feet at cruise altitude if everybody else at that altitude has the same error. Unless you're trying to clear mountains using an altimeter setting from a low-elevation field. It would be possibly unsafe for you to set your altimeter accurately when everyone else is setting it to the broadcast local altimeter setting. Absolutely -- no one is suggesting changing the altimeter setting. You just have to be aware of how inaccurate the altimeter is when obstacle clearance might be an issue. For example, if you are planning to clear a ridge by only 1000 ft in the winter, you might want to think again. All the best, David |
Different WAAS altitude readings | Wyatt Emmerich | Instrument Flight Rules | 21 | June 29th 04 07:27 PM |
GPS Altitude with WAAS | Phil Verghese | Instrument Flight Rules | 42 | October 5th 03 12:39 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
WAAS question -- altitude accuracy? | Craig Davidson | Piloting | 10 | September 23rd 03 09:56 PM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
