True on all counts...
BT "dennis" wrote in message k.net... The glider has a couple of things going for it. Power planes are seldom over 12:1 glide ratio and it is achieved at a higher speed than the glider. This means that the power plane covers about half the THEORETICAL glide distance of the glider. Said loudly. The speed ratio between the wind and the aircraft is a factor. A given wind speed will be a higher percentage of the glider's best glide speed and will result in a greater advantage to it's L/D downwind compared to a power plane with the same wind. The wind also works to advantage for the glider's on tow part by decreasing the distance that it covers on climb, compared to a power plane at typical climb speeds. Finally, for some ancient and illogical reason, power plane standard procedure is to stay on center line of the runway for climbout. It's considered bad form to put yourself in a safer position for a turn back to the field. The exception is an IFR departure. They typically maintain runway heading. Lots of luck making a turn back under IFR. You subtract reaction time, reconfiguration time, screw around trying to get the thing to run, and it is very, very unlikely that a power plane will get back to the runway at any time during their climb out. Unless it is a long runway and you started from the end. In article afjlb.63635$La.24804@fed1read02, "BTIZ" wrote: Most gliders can do this and the pilots train to that standard.. Departure problems below 200ft AGL, tow plane power problems.. rope breaks or tow hook failures.. and the idea is to land straight ahead as quickly as possible and get stopped. Above 200ft AGL (which most glider/tow combinations can get to about 3000ft after start of take off roll), if the rope breaks, tow plane says.. GET OFF!!.. the glider pilot can pitch down for airspeed and begin a turn back to the departure runway.. land opposite the direction of take off and have enough energy to roll back to the starting point. A nice tow pilot will allow the tow to "Drift down wind the cross wind" on climb out, so if something does happen the glider can turn into the wind when returning to the runway.. turning away from the wind can push the glider to far away (tailwind on base) and make returning to the runway more difficult. This maneuver is part of the practical test standards, though most DE's will wait until 300ft or higher and most CFIGs will review the procedure on BFRs. Our "Training glider" has a L/d of 23-1. Schweizer 2-33. BT "Harold" wrote in message . .. If a small single engine plane can out-climb its engine-out glide ratio from take off through the top of climb point, wouldn't it follow that it can always theoretically make it back to the departure airport in the event of engine failure ? Assuming straight out departure, no wind, and the altitude loss in the 180 turnback is offset by the runway portion you didn't use. If my best glide is 85 KTAS and it loses 700 fpm at that speed, shouldn't I be guaranteed I can make it back if I climb at 84 KTAS and 701 fpm ? |
Historic Helsinki-Malmi Airport in trouble - please read | Seppo Sipilä | General Aviation | 0 | December 24th 04 09:04 AM |
STAR to nearby airport | Viperdoc | Instrument Flight Rules | 33 | May 13th 04 10:48 PM |
The battle for Arlington Airport begins? | Paul Adriance | Home Built | 45 | March 30th 04 11:41 PM |
Here's the Recompiled List of 82 Aircraft Accessible Aviation Museums! | Jay Honeck | Home Built | 18 | January 20th 04 04:02 PM |
Student Pilot Stories Wanted | Greg Burkhart | Piloting | 6 | September 18th 03 08:57 PM |
