On Fri, 21 Nov 2003 19:38:50 -0600, Matt Ketcham wrote:
Just paid 200 for a IFR. Our shop doesn't differentiate between IFR and VFR checks. The shop I use charges $60 for a VFR check, and $180 for an IFR check. There is more work to the IFR check as I understand it. |
"Matthew P. Cummings" wrote in message gray.net...
On Fri, 21 Nov 2003 19:38:50 -0600, Matt Ketcham wrote: Just paid 200 for a IFR. Our shop doesn't differentiate between IFR and VFR checks. The shop I use charges $60 for a VFR check, and $180 for an IFR check. There is more work to the IFR check as I understand it. You don't need any pitot-static check for VFR. However, even in the Aeronca (no electrical) we used to have it checked. Good to know if you're really at 1000 feet. |
On Fri, 21 Nov 2003 19:38:50 -0600, Matt Ketcham wrote: Just paid 200 for a IFR. Our shop doesn't differentiate between IFR and VFR checks. The shop I use charges $60 for a VFR check, and $180 for an IFR check. There is more work to the IFR check as I understand it. BTW: I was scheduling a checkride for a student this summer and asked her to ensure her transponder check was current (she only flys VFR). We found the last one was more than 5 years ago and her checkride was the next day. She got really lucky to find a shop to do it. The reason I thought to double check was because the examiner called me up to tell me of this last minute opening because some "fool" showed up for his private checkride without a current transponder inspection. ![]() Probably the most overlooked inspection for the VFR pilot. Since the ELT usually gets done by the IA during annual, people assume the transponder is too. The problem is that the average IA isn't licensed to do the transponder check. -Robert, CFI |
Transponder test after static system opened? | Jack I | Owning | 6 | March 14th 04 03:09 PM |
Fixing the Transponder with Duct Tape and Aluminum Foil | Ron Wanttaja | Home Built | 45 | March 14th 04 12:18 AM |
transponder check? | Russell Duffy | Home Built | 10 | August 14th 03 11:36 PM |
Use of hand-held GPS on FAA check ride | Barry | Piloting | 3 | August 9th 03 10:14 PM |
Use of hand-held GPS on FAA check ride | Barry | Instrument Flight Rules | 1 | August 9th 03 09:25 PM |
