"Geoffrey Barnes" wrote in message nk.net...
If they did or if there is still too much fuel (weight), I am going to scrap the flight. I'm not going to worry about trying to get some fuel drained. Given the background for this flight, I don't think it would be worth the hassle. That's fine for this flight, but I am going to use your post to ask a question that I've had for some time. Let's say you do need to "dump fuel", to get the weight down. How do you do it? Does the FBO drain it for you? What do they drain it into? What would you do if you were at an unattended field? Can this drained fuel be saved and re-used at a later time, or do those bad FBO people keep it? I've had this done two or three times. The FBO treated it as normal procedure, and since I rent wet, there's no cost implication. The fuel truck can suck a metered amount of fuel out of the tanks and back into the truck, so it seems. One time it was for my checkride in a 152 (no tabs) - we filled it up and then took 6 gallons out, and I made sure the examiner knew it. -- David Brooks |
Cessna 414! Weight & Balance | [email protected] | General Aviation | 3 | February 24th 05 10:33 PM |
Weight and Balance | Dale Larsen | Home Built | 2 | June 23rd 04 05:11 PM |
Pitts S-1 weight and balance | wallyairplanefan | Aerobatics | 2 | March 6th 04 04:09 AM |
Weight and balance question. | Wayne | Piloting | 5 | November 28th 03 06:45 PM |
Question ~ Does fuel injection add weight? | Barnyard BOb -- | Home Built | 0 | July 6th 03 09:47 PM |
