Background first: Two significant points exist for calibrating a
temperature probe or thermometer without comparing it to a known probe or thermometer -- freezing and boiling points of water. For the freezing point, one mixes up a slush of ice and water, the probe should read zero degrees centigrade when immersed in the liquid. For the boiling point, stick the probe in a pot of boiling water and it should read 100 degrees. Except, of course, for the barometric pressure. We all know water boils at lower and lower temperatures (?? 3 degrees per 1,000 feet??) as altitude is increased. Question: Why doesn't the same pressure effect occur for the freezing point? Oh yeah, to make this an aviation related topic consider calibrating a temperature probe or thermometer to use as a reference to check the OAT gauge in your plane once in a while. You all do that now and then, don't you? |
"Casey Wilson" wrote in message
... Question: Why doesn't the same pressure effect occur for the freezing point? I believe it does. If I recall correctly, the pressure from the blade of an ice skate is what melts the ice and allows the skate to glide easily across the ice. However, it requires a much greater change in pressure to make the same change in freezing point, so it's not relevant for your purpose. All off the top of my head...look it up if you really want to know. ![]() Pete |
... I believe it does. If I recall correctly, the pressure from the blade of an ice skate is what melts the ice and allows the skate to glide easily across the ice. I don't doubt your recall, Peter, as I'm sure I was taught the same. However, check out: http://www.physlink.com/Education/AskExperts/ae357.cfm Julian Scarfe |
"Julian Scarfe" wrote in message
... I don't doubt your recall, Peter, as I'm sure I was taught the same. However, check out: http://www.physlink.com/Education/AskExperts/ae357.cfm Interesting. Oh well... I'm at least relieved to find that it is indeed the case that the melting point changes with pressure, and that it changes very little. It just changes a lot less than I even suspected. ![]() The explanation on that page *is* a little confusing though. I think they got their math right, but the wording is odd. They start out talking about the reduction of freezing point, but then later talk about an increase in the temperature of the ice. The two are not really the same, even if they result in the same effect. Pete |
![]() "Julian Scarfe" wrote in message ... "Peter Duniho" wrote in message ... I believe it does. If I recall correctly, the pressure from the blade of an ice skate is what melts the ice and allows the skate to glide easily across the ice. I don't doubt your recall, Peter, as I'm sure I was taught the same. However, check out: http://www.physlink.com/Education/AskExperts/ae357.cfm Julian Scarfe I don't buy the physicist's argument. Blades are curved, so there is likely ten times less surface area on the ice. -- Jim in NC |
"Morgans" wrote in message ... I don't buy the physicist's argument. Blades are curved, so there is likely ten times less surface area on the ice. ....which would make the depression of freezing point 0.2 degC. Still not enough. Julian |
He is all wet.... Good thing for his employer he is retired.. I hope I
don't use any products he was part of designing... Skate blades have a rocker bottom, like a boat hull, limiting the area of steel in contact with the ice, which radically raises the pounds per square inch of pressure, applied (PSI) at the contact patch... Further, the skating edge is ground concave, not flat, so that two knife edges raise the PSI to huge levels at the minute points of contact between the edge(s) and the ice, liquifying the ice instantly, and the wedging action of the inside profile of the concavity then squirts the liquid towards the center of the concavity raising the blade up onto a hydrostatic wedge of water... Same hydrostatic phenomena that keeps your crankshaft from welding to the rod bearings... Same logarithmic rise in pressure at the wedge point phenomena that allows a sharp knife to cut more easily than a dull knife... As far as unsatisfied hyrdrogen bonds at the interface between ice and air, I suspect that is true but that is not what makes a skater glide... Get your kid on skates and take a magnifying glass with you and look at the fresh skate track and you will see how the ice liquified and then refroze instantly leaving a different ice surface in the track than on the ice adjacent to the track... Try the same test with a skate blade ground flat, or even a little convex, on the bottom (make sure your kid is well padded)... Experts!!! ya gotta love em... Denny " Morgans" wrote in message I don't buy the physicist's argument. Blades are curved, so there is likely ten times less surface area on the ice. -- Jim in NC |
... Background first: Two significant points exist for calibrating a temperature probe or thermometer without comparing it to a known probe or thermometer -- freezing and boiling points of water. For the freezing point, one mixes up a slush of ice and water, the probe should read zero degrees centigrade when immersed in the liquid. For the boiling point, stick the probe in a pot of boiling water and it should read 100 degrees. Except, of course, for the barometric pressure. We all know water boils at lower and lower temperatures (?? 3 degrees per 1,000 feet??) as altitude is increased. Question: Why doesn't the same pressure effect occur for the freezing point? It does. For a phase change, there's an equation called the Clapeyron equation that shows how the temperature varies with pressure. dT/dP = T deltaV / deltaH where deltaV is the volume change and deltaH is the enthalpy change (think of it as energy and you're not too far off) of the phase change. (It sort of makes sense that the pressure variation of the phase change depends on what the volume change is. If there's no volume change it doesn't really matter what the pressure is, as everything happens in the same space.) For water - steam, deltaV is very large, so the variation of T with P is significant. For ice-water, deltaV is tiny, so the variation of T with P is miniscule. At about 130 atmospheres, the melting temperature of water drops by 1 degC. Julian Scarfe |
Julian, that's the complex answer. Remember PV=nRT?
This is what I use... Change it to PV/T=nR From this you can write: (P1V1)/T1=(P2V2)/T2 Julian Scarfe wrote: It does. For a phase change, there's an equation called the Clapeyron equation that shows how the temperature varies with pressure. dT/dP = T deltaV / deltaH where deltaV is the volume change and deltaH is the enthalpy change (think of it as energy and you're not too far off) of the phase change. (It sort of makes sense that the pressure variation of the phase change depends on what the volume change is. If there's no volume change it doesn't really matter what the pressure is, as everything happens in the same space.) For water - steam, deltaV is very large, so the variation of T with P is significant. For ice-water, deltaV is tiny, so the variation of T with P is miniscule. At about 130 atmospheres, the melting temperature of water drops by 1 degC. Julian Scarfe |
"john smith" wrote in message
... Julian, that's the complex answer. Remember PV=nRT? PV=nRT does not apply to solids or liquids. Hell, it barely applies to gasses, since they rarely are "ideal". Pete |
Total Air Temperature question | Mike Rapoport | Instrument Flight Rules | 12 | December 14th 04 06:20 PM |
Total Air Temperature question | Julian Scarfe | General Aviation | 6 | December 14th 04 06:20 PM |
Total Air Temperature question | Mike Rapoport | General Aviation | 5 | December 11th 04 09:30 PM |
'Room Temperature' | Anthony | Home Built | 11 | August 23rd 04 07:36 PM |
Wanted to Buy/Trade: CTH Bayonet Type Probes | aRKay | Aviation Marketplace | 0 | August 14th 04 03:40 PM |
