Julian, that's the complex answer. Remember PV=nRT?
This is what I use... Change it to PV/T=nR From this you can write: (P1V1)/T1=(P2V2)/T2 Julian Scarfe wrote: It does. For a phase change, there's an equation called the Clapeyron equation that shows how the temperature varies with pressure. dT/dP = T deltaV / deltaH where deltaV is the volume change and deltaH is the enthalpy change (think of it as energy and you're not too far off) of the phase change. (It sort of makes sense that the pressure variation of the phase change depends on what the volume change is. If there's no volume change it doesn't really matter what the pressure is, as everything happens in the same space.) For water - steam, deltaV is very large, so the variation of T with P is significant. For ice-water, deltaV is tiny, so the variation of T with P is miniscule. At about 130 atmospheres, the melting temperature of water drops by 1 degC. Julian Scarfe |
"john smith" wrote in message
... Julian, that's the complex answer. Remember PV=nRT? PV=nRT does not apply to solids or liquids. Hell, it barely applies to gasses, since they rarely are "ideal". Pete |
Total Air Temperature question | Mike Rapoport | Instrument Flight Rules | 12 | December 14th 04 06:20 PM |
Total Air Temperature question | Julian Scarfe | General Aviation | 6 | December 14th 04 06:20 PM |
Total Air Temperature question | Mike Rapoport | General Aviation | 5 | December 11th 04 09:30 PM |
'Room Temperature' | Anthony | Home Built | 11 | August 23rd 04 07:36 PM |
Wanted to Buy/Trade: CTH Bayonet Type Probes | aRKay | Aviation Marketplace | 0 | August 14th 04 03:40 PM |
