"Nomen Nescio" ] wrote in message
... read the question again Question: Why doesn't the same pressure effect occur for the freezing point? The key word here is SAME. As temp. approaches 0 deg.C, vapor pressure approaches 0 mmHg. No it doesn't. The vapor pressure of water (and ice) at 0 degC is about 6 mbar (about 4 mmHg). There's nothing special about 0 degC as far as the vapor pressure is concerned. Since the boiling point is the temp where vapor pressure equals atmospheric pressure. The "SAME PRESSURE EFFECT" is effectively nonexistent. Over an atmospheric pressure ranging from say 5 - 14.7 psi, the change in the melting point of ice is virtually nonexistent and can be ignored for all practical purposes in answering the original question. You're trying to complicate a question that can be answered quite simply. But the whole question is *why* is "the change in the melting point of ice virtually nonexistent". As far as I can see it has nothing to do with the vapor pressure. While Rich's comment was not the friendliest I've seen on Usenet, he does have a point. Julian Scarfe |
Total Air Temperature question | Mike Rapoport | Instrument Flight Rules | 12 | December 14th 04 06:20 PM |
Total Air Temperature question | Julian Scarfe | General Aviation | 6 | December 14th 04 06:20 PM |
Total Air Temperature question | Mike Rapoport | General Aviation | 5 | December 11th 04 09:30 PM |
'Room Temperature' | Anthony | Home Built | 11 | August 23rd 04 07:36 PM |
Wanted to Buy/Trade: CTH Bayonet Type Probes | aRKay | Aviation Marketplace | 0 | August 14th 04 03:40 PM |
