On Sun, 11 Jan 2004 14:00:42 GMT, "Roger Long"
om wrote: Has anyone heard or experienced this? On changing the battery in our plane the other day, the A&P said, "You had a battery explosion." On looking closely, I could see that the box was bowed out and rounded as if someone had tried to inflate it with air. I'd noticed that it wasn't exactly square and the cover didn't fit very well but thought it was just poor workmanship. He said it probably happened during starting from hydrogen build up that the propwash hadn't had a chance to blow away yet and the pilot thought it was a backfire. No harm done except we'll need a new box because of corrosion. It could have happened years ago. -- Roger Long I've seen it twice and had a close call on my own battery one winter's day. I was an auto mechanic in another life and happened to be watching a nearby Peugeot mechanic working on a dead car that had just been dragged in. I think I helped push it in, in fact. I'd moved away from the car and was about twenty feet off when the old dude who worked on those things connected the charger to the battery. It instantly exploded, scattering pieces of plastic and acid all over the shop. The mechanic was scratched in a few places (painfully as the cuts got splattered with acid) but was otherwise unharmed, including his eyes as he was wearing glasses. He was lucky. I saw another explode when a guy tried charging a frozen battery. I mean literally, the acid was so diluted from being discharged that it froze. That battery blew apart, but due to the ice, it wasn't a huge explosion. The time my own battery tried to explode, I'd removed all the battery caps before attempting to charge it. I'd connected the charger, making the negative connection away from the battery as you are supposed to to lower the possibility of causing a spark near the battery. I was removing the charger and failed to removed the negative side first. This caused a spark and the escaping hydrogen instantly blew up. But since the caps were off the battery, it only resulted in a loud POP as the hydrogen ignited and it did no damage to the battery or me. There's a reason you are told to attach the positive lead first, and connect the ground to something away from the battery. Problem is, sometimes this results in such a poor connection that jumping the dead battery is problematic. Corky Scott |
Batteries, charger for Yaesu handheld - NiCad or NiMH? | David Herman | Owning | 10 | November 7th 04 04:30 PM |
Battery Replacement and Cold Cranking Amps | O. Sami Saydjari | Owning | 27 | February 2nd 04 02:38 PM |
Battery storage? | Roger Long | Owning | 10 | January 14th 04 02:35 PM |
Icom A5 Battery Tester ?? | Harry Gordon | Piloting | 5 | January 10th 04 01:29 PM |
ICom A-5 Question - Battery Level Indicator | Harry Gordon | Piloting | 22 | December 5th 03 12:07 AM |
