![]() "Glenn Westfall" wrote in message ... Does anyone know of any adapters or such that would allow hooking up an audio recorder to record all cockpit communications? ie, both transmissions to ATC and conversations to other passengers. Thanks, Glenn Glenn, Not an answer to your question, but are you in Ft. Worth? |
On Thu, 22 Jan 2004 13:17:58 GMT, "Chuck"
wrote: "Glenn Westfall" wrote in message .. . Does anyone know of any adapters or such that would allow hooking up an audio recorder to record all cockpit communications? ie, both transmissions to ATC and conversations to other passengers. Thanks, Glenn Glenn, Not an answer to your question, but are you in Ft. Worth? No...I am in Okinawa at the moment. I am from Southern CA. |
![]() "Glenn Westfall" wrote in message ... On Thu, 22 Jan 2004 13:17:58 GMT, "Chuck" snip Glenn, Not an answer to your question, but are you in Ft. Worth? No...I am in Okinawa at the moment. I am from Southern CA. OK... I worked with a Glenn Westfall until about 6 months ago... Just checking... |
backup cockpit lighting | Josef Burger | Instrument Flight Rules | 35 | January 2nd 05 01:23 AM |
Antonov vs Galaxy cockpit | Emilio | Military Aviation | 13 | July 2nd 04 06:15 AM |
Survey - 3 blade prop conversion- Cockpit vibration, happy or not | Fly | Owning | 20 | June 30th 04 05:32 PM |
What are you guys using for cockpit lights these days? | Stealth Pilot | Home Built | 6 | December 9th 03 09:14 AM |
FS DeHavilland Open Cockpit Chipmunk | [email protected] | Aviation Marketplace | 0 | October 14th 03 11:10 AM |
