OK, why do they cover the prop?
Old February 2nd 04, 06:05 AM
Peter Duniho
"Dale" wrote in message
My prop cover was insulated so it did more than just keep frost from
forming on it.
How did it do that? Did your prop have an internal heat source? Other than
keeping frost from your prop, what did the insulated cover do?
Pete
Old February 2nd 04, 06:42 AM
Dale
It kept the prop from dissipating the heat applied to the engine by my
pre-heater.
That McCauley was an 82 inch heat-sink.
Dale L. Falk
Old February 2nd 04, 07:24 AM
Peter Duniho
pre-heater.
Interesting. I didn't realize so much heat could be transferred through the
crankshaft. I guess it makes sense though...the prop does have a lot of
surface area, so heat flow is easy to have.
On the bright side, with the engine pre-heater pumping heat through the
prop, you didn't have to worry about frost.
Pete
Old February 2nd 04, 02:20 PM
Dan Thomas
"Peter Duniho" wrote in message ...
pre-heater.
There's an AD against Lycomings of 160 HP and over using
fixed-pitch props that demands an inspection of the internal bore of
the front end of the crank. This end stays pretty cool when the engine
is running, even in warm weather, and the low temp causes condensation
to form in that bore, which is open to the crankcase, and the water
and oil form acidic sludge that eats pits in the bore and weakens the
crank. I think there has been only one failure so far, though a lot of
cranks have been found with the pitting. Constant-speed props use that
bore (plugged off at the rear) to feed oil to the prop, so it's not a
problem. And I suppose a composite or wooden prop would be much
better, not wicking away so much heat.
Dan
Right prop, wrong prop? Wood prop, metal prop? Gus Rasch Aerobatics 1 February 14th 08 10:18 PM
Ivo Prop on O-320 Dave S Home Built 14 October 15th 04 03:04 AM
This week's AW&ST: apparently THAAD will have some ABM (as in anti- *ICBM*) capability. Scott Ferrin Military Aviation 29 August 31st 04 04:20 AM
IVO props... comments.. Dave S Home Built 16 December 6th 03 11:43 PM
Metal Prop vs. Wood Prop Larry Smith Home Built 21 September 26th 03 07:45 PM
