recording communications
Old February 10th 04, 02:41 AM
Casey Webster
Default recording communications
i recently got access to a sony digital camcorder, and am going to take it
up for a flight (passenger recording of course), and i wanted to patch in
the intercom to its audio inputs. What is neccessary to adapt what comes
out of the intercom to make it suitable for line level inputs to a
camcorder? If anyone has made such a cable, or knows a place that sells
them, i'd be interested in hearing from you. thanks.
-casey
Old February 10th 04, 03:57 AM
John T
"Casey Webster" wrote in message
What is
neccessary to adapt what comes out of the intercom to make it
suitable for line level inputs to a camcorder? If anyone has made
such a cable, or knows a place that sells them, i'd be interested in
hearing from you.
http://tinyurl.com/2jq5x
I've heard of folks having success simply plugging a direct patch cord (no
in-line resistor) available from Radio Shack directly into the Sony camera.
I personally use a portable intercom with an audio out jack.
John T
http://tknowlogy.com/TknoFlyer
http://www.pocketgear.com/products_s...veloperid=4415
____________________
Old February 10th 04, 05:20 AM
Craig Prouse
If you pull a few key words out of your post and Google the r.a.*
archives, you'll find lotsa lotsa suggestions.
Old February 10th 04, 07:20 AM
Hilton
Hi,
Plug a tiny microphone into your camcorder and stick it in the cup of your
headset. Works amazingly well, cheap, no messing with wires/impedences etc,
and you get both the intercom and ambient (engine etc) sounds.
Hilton
Old February 10th 04, 03:01 PM
Newps
Hilton wrote:
Hi,
Yes, but you don't get what the pilot says over the radio or intercom.
I have a Sony camcorder and you simply get a cord with a stereo minijack
at either end if your camcorder is stereo, if it's mono get a mono plug
on either end. You will need a mini to regular jack adapter for the
airplane end. If someone will be sitting in the copilot seat then also
get a Y adapter so the audio can go to both the passenger and the camera.
Old February 10th 04, 03:27 PM
Casey Wilson
"Newps" wrote in message
news:En6Wb.265751$I06.2851145@attbi_s01...
Hilton wrote:
Hi,
your
etc,
Eh? Are you sure you don't hear yourself when you talk on the intercom or
radio? My intercom has a sidetone that carries my voice quite nicely into
the Radio Shack ceramic button mike that I have plugged into a digital voice
recorder. The tiny mike is unnoticable when stuck into the headset cup. It
could be plugged into the camcorder just as well as the voice recorder.
Old February 11th 04, 12:54 PM
CFLav8r
John T
John,
I have a portable David Clark intercom with the audio out jack,
but when I picked up a cable at Radio Shack and plugged it into my
Sony camera (mic input) it didn't pickup any sound.
The camera does however state (plug in power) just below the mic
input but I'm not quite sure what that means.
Any suggestions?
David (KORL)
Old February 11th 04, 01:21 PM
John T
"CFLav8r" wrote in message
m
I don't use DC headsets, but I can think of a couple things to check.
First, are the DCs stereo? That *may* affect the audio out jack, but I
wouldn't count on it. Also, make sure the volume is turned up on the
headset (kinda hard to miss that one if you're wearing them .
Second, make sure the audio cable is plugged in to the red mic/power jack on
your Sony. My model has a green headphone jack and a red mic/power jack as
you described.
John T
Old February 12th 04, 05:37 AM
Hilton
Hi,
Excellent results are achieved by buying a tiny microphone, plugging it into
the camera, and placing it in your headset's ear cup. You get the intercom
and ambient sound in a good ratio. It works great, is fool/failure-proof
and doesn't have you messing with impedences etc etc etc.
Hilton
Old February 12th 04, 05:19 PM
Dylan Smith
I had excellent results by making a cable with a small jack for the
camcorder at one end, and a large jack that plugged into the intercom at
the other. Concealed within the large jack was a 47K ohm (IIRC) variable
resistor. It turned out it needed all 47K ohms to get the levels
right. I'm sure there is more correct ways of impedance matching, but
analogue electronics is not my thing :-)
I built the cable by buying a mono-to-stereo cable at Radio Shack and
chopping off the mono end and putting my custom jack on that end.
Dylan Smith, Castletown, Isle of Man
Flying: http://www.dylansmith.net
Frontier Elite Universe: http://www.alioth.net
"Maintain thine airspeed, lest the ground come up and smite thee"
camcorder recording Cessna intercom audio question Marty from Sunny Florida Owning 7 November 15th 04 04:26 PM
Recording cockpit voices Glenn Westfall Piloting 20 January 27th 04 03:09 PM
Recording your flight time Jay Honeck Piloting 50 December 23rd 03 03:23 PM
Speedbird Concorde Alpha Foxtrot's last ATC recording Koopas Ly Piloting 0 November 29th 03 02:27 PM
Military HF communications under attack Gene Storey Military Aviation 28 October 2nd 03 04:24 AM
