Recording cockpit voices
Old January 22nd 04, 07:55 AM
Glenn Westfall
Default Recording cockpit voices
Does anyone know of any adapters or such that would allow hooking up
an audio recorder to record all cockpit communications? ie, both
transmissions to ATC and conversations to other passengers.
Glenn
Old January 22nd 04, 12:38 PM
John T
"Glenn Westfall" wrote in message
Assuming your aircraft has an intercom, you can make a direct-connect cable
using Gene Whitt's directions found he
http://tinyurl.com/36x3c
I typically use a portable intercom that has an audio out jack. I use a
patch cord to connect that to either my voice recorder or my video recorder.
Having the portable intercom handy also provides a battery-powered backup
for the plane's intercom (actually used in that capacity once).
John T
http://tknowlogy.com/TknoFlyer
http://www.pocketgear.com/products_s...veloperid=4415
____________________
Old January 22nd 04, 03:33 PM
Ben Smith
cable
I've made one of these cables, and they work good. I don't mess with tapes,
though. I bought an Olympus DM-1 digital recorder.. With the included 64MB
Smart Media, it will record for 10 hours on best quality. Double that if
you get a 128MB card. (Which is the max you can use). It also plays back
MP3/WMA format music files too.
Here's a small .wav clip from one of my recordings:
http://tinyurl.com/2ycds
Ben
C-172 - N13258 @ 87Y
Old January 22nd 04, 08:26 PM
Andrew Sarangan
"Ben Smith" wrote in message ...
cable
I record all my flights with students using a tiny digital recorder. I
have a very simple system that works wonderfully. You don't have to
tap into the intercom system. It is so simple that I record every
single flight, whether it is useful or not. I have written an article
about the setup on my website.
http://www.geocities.com/asarangan/aviation (and click on Cockpit
Voice Recorders).
Old January 22nd 04, 09:07 PM
Gary Drescher
"Andrew Sarangan" wrote in message
om...
Voice Recorders).
That's pretty cool. Even more straightforwardly, if you have a spare
headset and intercom station, you can just give the recorder its own
headset, pressing the two ear pieces together with the recorder in between.
I think I'll try that next time I fly.
--Gary
Old January 22nd 04, 10:16 PM
G.R. Patterson III
Would the "pilot isolate" or "crew isolate" feature interfere with that?
George Patterson
Great discoveries are not announced with "Eureka!". What's usually said is
"Hummmmm... That's interesting...."
Old January 22nd 04, 09:42 PM
Glenn Westfall
After I posted this message I started thinking about it. Would this
work? Plug in a headphone adapter that goes from the big size to the
small walkman size in an unused intercom jack. Run an extension cable
from the adapter to the mic in on a recorder or video camera. That
shoud do the trick correct? The headphone jack of aviation headsets
are standard size and can be converted to the smaller size.
On 22 Jan 2004 12:26:06 -0800, (Andrew
cable
Voice Recorders).
Old January 22nd 04, 11:02 PM
John T
Would this
Not necessarily. You have to consider the impedance differences.
John T
Old January 23rd 04, 03:18 AM
Andrew Sarangan
The impedance of the aircraft headsets are quite different than the
audio inputs of walkmans (I can't recall the numbers). You could use
an impedance matching network, but now things are starting to get
complicated.
Since I use the recorder for flight instruction, and since I fly a
dozen different aircrafts, I did not want to rely on tapping into the
intercom system. Every intercom is different, and what worked in one
airplane may not work in another. With my arrangement (condenser
microphone in the headset), it works in all airplanes equally.
If anyone wants to listen to the audio quality from my setup, I will
be happy to email you a clip.
(Glenn Westfall) wrote in message ...
(Andrew
cable
Voice Recorders).
Old January 23rd 04, 10:16 PM
Marco Leon
I did exactly that with my Sony TRV18 Digital camera. It works like a chram.
If you mount the camera in the back seat, just make sure you have it high
enough to almost hit the roof. Otherwise you will see nothing but the panel.
It's good to see the runway.
Marco
cable
tapes,
64MB
if
back
Voice Recorders).
Posted Via Usenet.com Premium Usenet Newsgroup Services
** SPEED ** RETENTION ** COMPLETION ** ANONYMITY **
http://www.usenet.com
backup cockpit lighting Josef Burger Instrument Flight Rules 35 January 2nd 05 01:23 AM
Antonov vs Galaxy cockpit Emilio Military Aviation 13 July 2nd 04 06:15 AM
Survey - 3 blade prop conversion- Cockpit vibration, happy or not Fly Owning 20 June 30th 04 05:32 PM
What are you guys using for cockpit lights these days? Stealth Pilot Home Built 6 December 9th 03 09:14 AM
FS DeHavilland Open Cockpit Chipmunk [email protected] Aviation Marketplace 0 October 14th 03 11:10 AM
