On Wed, 31 Mar 2004 10:25:02 GMT, "Roger Long"
om wrote: This is the procedure we use on our O-320 and have had noticeably smoother and quicker starts since we started it: RPM - 1200 Lean for maximum RPM rise. (Don't worry, no amount of leaning will hurt the engine at this low power) Run 20 seconds Throttle - Quickly to Idle Mixture - Idle Cut Off Switches - OFF Leaning for all ground operations is vital to keep the mags clear on this engine. On startup and after exiting the active runway, set RPM to 1000 and lean slowly for maximum RPM rise. This will often be about 100. Lean slightly past until RPM just starts to fall. If the engine runs a hair rough, that's OK. It will be lean enough that it will start to stumble and quit if you try to run it faster than about 1300. This means you can't accidentally take off with it leaned. Since we started doing this, I have only had to clear a mag a couple of times in two years. Roger Long Roger, when you say "clear a mag" do you mean clearing plugs? Because it isn't the mag that fouls, is it? Isn't it the plugs? Thanks, Corky Scott |
Yes, it is the plugs. Since you switch a mag off people often say clearing
a mag even though it's sort of like saying "digging a shovel". Mags do foul for very different reasons but the only way to clear them is with a wallet. -- Roger Long Roger, when you say "clear a mag" do you mean clearing plugs? Because it isn't the mag that fouls, is it? Isn't it the plugs? Thanks, Corky Scott |
My Engine Fire!! | [email protected] | Piloting | 21 | April 2nd 04 05:02 PM |
Starting Engine Question (O-320, Warrior) | Lisa | Piloting | 13 | April 1st 04 06:45 AM |
My Engine Fire!! | [email protected] | Owning | 1 | March 31st 04 01:41 PM |
engine overhaul & autopilot question | CriticalMass | Owning | 8 | February 13th 04 06:11 PM |
Corky's engine choice | Corky Scott | Home Built | 39 | August 8th 03 04:29 AM |
