Thanks for the ideas. Most won't work tho. These are rectangular
inspection holes with screws holding the cover plates on. The enlarged holes are in the thickened fabric sections (there may be some plastic embedded in there, but it doesn't look like it) The holes that go into wood are fine. I was hoping that somebody would have experience with a glue/epoxy something that could be used to fill in the old holes without harming the fabric. Sorry I can't take a picture, I'm on call this week and can't get up to the airport. Brian Huffaker ) RV-8A #80091 Riviting lower fuse subfloor Starduster Too N23UT flying |
Brian Huffaker wrote:
Thanks for the ideas. Most won't work tho. These are rectangular inspection holes with screws holding the cover plates on. The enlarged holes are in the thickened fabric sections (there may be some plastic embedded in there, but it doesn't look like it) The holes that go into wood are fine. I was hoping that somebody would have experience with a glue/epoxy something that could be used to fill in the old holes without harming the fabric. Sorry I can't take a picture, I'm on call this week and can't get up to the airport. Brian Huffaker ) RV-8A #80091 Riviting lower fuse subfloor Starduster Too N23UT flying Someone already suggested making backing plates from thin aluminum sheet metal. Personally, that's the way I think I'd go about it. Use clear shoe-goo to install the backing plates inside the fabric? That should hold it in place when all the screws are removed. It sounds like you are just screwing to the fabric in places... Best of luck, Richard Lamb |
Double covering fabric covered wings | [email protected] | Home Built | 9 | May 9th 04 08:39 PM |
Fabric repair | D.A.L | Home Built | 0 | April 27th 04 07:17 PM |
Fabric covering processes | Jerry Guy | Home Built | 2 | January 29th 04 06:49 PM |
Fabric Work | Doug | Home Built | 9 | January 26th 04 03:31 AM |
Bothersome Phillips Head Screws | Larry Smith | Home Built | 48 | January 10th 04 04:26 AM |
