On the B727, the Captain's or F/O's static sources are selectable from
Normal to "Alternate", which would provide the static instruments with static air which is used for the Mach Airspeed Warning and Pressurization systems "Marc Lattoni" wrote in message news:c3%hc.1386$2q2.192@edtnps84... Last night on Discovery Channel there was a story of a Peruvian 757 that went down because the two static ports had been taped over for cleaning and not removed. As you might imagine, the airspeed indicator and altimeter gave erroneous readings and fed the onboard computers erroneous data; after a series of bizarre warning messages (zero airspeed and "over speed warning" from the computer) the pilots attempted to correct for contradictory information and multiple warnings and the plane crashed into the ocean Do modern airliners not have an alternate static source as on my 172? Marc |
Marc,
The Canadair Regional Jet has a three static sources. They are selectable from normal to alternate. This usually cross connects the Captains to the F/O and vice versa. The third one is independent for the Mach speed transducer and the Cabin Pressure Acquisition module. It would be safe to assume that if one or more of the static port was taped over for painting then all of them were taped over. Our Turbo Props do not have a selectable static source. They do have selectable Air Data computers though. Michelle Marc Lattoni wrote: Last night on Discovery Channel there was a story of a Peruvian 757 that went down because the two static ports had been taped over for cleaning and not removed. As you might imagine, the airspeed indicator and altimeter gave erroneous readings and fed the onboard computers erroneous data; after a series of bizarre warning messages (zero airspeed and "over speed warning" from the computer) the pilots attempted to correct for contradictory information and multiple warnings and the plane crashed into the ocean Do modern airliners not have an alternate static source as on my 172? Marc -- Michelle P ATP-ASEL, CP-AMEL, and AMT-A&P "Elisabeth" a Maule M-7-235B (no two are alike) Volunteer Pilot, Angel Flight Mid-Atlantic Volunteer Builder, Habitat for Humanity |
![]() "Marc Lattoni" wrote in message news:c3%hc.1386$2q2.192@edtnps84... Do modern airliners not have an alternate static source as on my 172? Modern airliners have multiple static ports, but they do not have one like your 172. The alternate static port in your 172 uses cabin air. Airliners are pressurized, so an alternate static port like on the 172 would be worthless. |
"C J Campbell" wrote in message
... Modern airliners have multiple static ports, but they do not have one like your 172. The alternate static port in your 172 uses cabin air. Airliners are pressurized, so an alternate static port like on the 172 would be worthless. I wonder. After all, the time you'd really need the alternate static port, you'd be low enough for the cabin to be left unpressurized. More than likely, the pilots would notice the need for alternate static reference before they climbed above an altitude where pressurization is required. I can believe that pressurized transport category airplanes don't bother with a cabin-vented alternate static port, as a matter of the designers not bothering to provide that. But I don't see any reason why that wouldn't be a feasible safety feature. Just select the cabin-vented alternate static port, and allow the cabin to climb to ambient pressure altitude. Pete |
Do modern airliners not have an alternate static source as on my 172? They have alternate static, but it's not as simple as the one on your 172. If yours is like most spamcan alternate static sources, it opens the static system to the cabin air. Simple and almost foolproof, but that sort of system wouldn't work on a pressurized airplane. The artificially high cabin pressure would generate erroneous readings. A pressurized airplane would have to have its alternate static source open to the outside air (where it can be taped over). John Galban=====N4BQ (PA28-180) |
went down because the two static ports had been taped over for cleaning That and many other stories are recounted in a book (I got it as a gift) called "The Black Box" and there appears to be a new edition out. Many of the stories have transcripts of radio conversations, and there's background information on the crews and circumstances as well as the information later gathered about the incidents, many of which are unfortunately fatal crashes. The events often seem to have been avoidable and in some cases you'll read it shaking your head over the carelessness or lack of communication that clearly led to poor decisions. I'd recommend it, though it's depressing reading and you should never let your nonpilot friends read it! http://www.amazon.com/exec/obidos/tg...-3567979-74566 41?v=glance |
Is my static port leaking? | Derrick Early | Instrument Flight Rules | 2 | August 15th 04 01:13 AM |
What caused the VSI and ALT bouce in the IMC? | cpu | Instrument Flight Rules | 38 | May 5th 04 03:45 PM |
Transponder test after static system opened? | Jack I | Owning | 6 | March 14th 04 03:09 PM |
Why a static port? | Paul Mennen | Owning | 11 | August 19th 03 04:58 AM |
Static in KX-165A | Chad Lemmen | Owning | 3 | July 21st 03 09:57 PM |
