Anyone know the reasoning for running the intake tubes through the hot oil
in the sump? |
Dale Larsen wrote:
: Anyone know the reasoning for running the intake tubes through the hot oil : in the sump? 1. Make oil not so hot 2. Make package more compact 3. Reduce power 4. Decrease detonation margin. 1&2: good 3&4: notsogood -- ************************************************** *********************** * The prime directive of Linux: * * - learn what you don't know, * * - teach what you do. * * (Just my 20 USm$) * ************************************************** *********************** |
Richard Riley wrote:
On Sun, 06 Jun 2004 17:46:41 GMT, Richard Lamb wrote: :And help reduce suceptability to carb icing. I've always heard that, but how? Carb ice, AFAIK, results from the air cooling as it accellerates through the venturi, and from the temprature drop from the gasoline evaporating. Both of those things happen in the carb, before the fuel/air mix goes through the hot oil-bath intake tubes. I'm sure there's some heat conducted from the hot oil pan to the carb itself, keeping it a little warmer. But does carb ice form downstream of the carb, within intake tubes, in a Cont? Probably just via conduction of the intake pipes. They do get quite warm... All I said was 'reduce suceptability' - not prevent. Even Lycomings need carb heat at times, but they don't seem to be as critical as Continentals. Richard |
Richard Riley wrote: : On Sun, 06 Jun 2004 17:46:41 GMT, Richard Lamb : wrote: : :And help reduce suceptability to carb icing. : I've always heard that, but how? : Carb ice, AFAIK, results from the air cooling as it accellerates : through the venturi, and from the temprature drop from the gasoline : evaporating. Both of those things happen in the carb, before the : fuel/air mix goes through the hot oil-bath intake tubes. : I'm sure there's some heat conducted from the hot oil pan to the carb : itself, keeping it a little warmer. But does carb ice form downstream : of the carb, within intake tubes, in a Cont? That's pretty much the explanation I've heard/accepted. I'm not too familiar with the Cont. induction system, but I think the carb body isn't heated by bolting it to the oilpan. I've gotten carb ice in my Lycoming O-360 a couple of times... usually in classically expected conditions (40-50degrees, foggish, low MP at low altitudes so lots of expansion) -Cory -- ************************************************** *********************** * The prime directive of Linux: * * - learn what you don't know, * * - teach what you do. * * (Just my 20 USm$) * ************************************************** *********************** |
Some engine design need to heat the intake side to prevent condense in the
tubes that lead to engines that run rough, this is a normal design on carb engines, even in cars. it also prevent ice in the tubes but that is not the main goal, even cars use warm air to heat the intake air in the carburator and tube, manually changed (winter/summer) or by a thermostat Jan Carlsson www.jcpropellerdesign.com "Dale Larsen" skrev i meddelandet news:GvGwc.53250$eY2.35696@attbi_s02... Anyone know the reasoning for running the intake tubes through the hot oil in the sump? |
| Thread Tools | |
| Display Modes | |
| O-235 Lycoming Mods | Do B | Home Built | 2 | March 19th 04 03:42 PM |
| Remove oil seal from vacuum pump adapter on Lycoming IO320 HOW????? | Ron | Home Built | 2 | February 24th 04 05:34 PM |
| Lycoming Sued | jls | Home Built | 0 | February 13th 04 03:01 PM |
| Weight of Lycoming O290 | Ray Toews | Home Built | 1 | December 22nd 03 12:56 AM |
| Lycoming 320 and EAA Light Sport Aircraft ? | Dave Jackson | Home Built | 29 | October 20th 03 02:20 AM |
