Transponder causing problems for Airlines on final ????
Old June 14th 04, 04:07 PM
Garner Miller
In article , EDR
Sounds like TCAS
TCAS only works with Mode-S transponders.
Who told you that? A Mode C transponder looks the same on a TCAS
screen as Mode S. The only difference is that two Mode-S-equipped
airplanes are able to coordinate a TCAS maneuver (so both airplanes
won't get told "climb" and climb into each other).
TCAS will interact and with Mode C transponders just fine, and will
even show and give a traffic advisory for aircraft with no altitude
encoding at all.
Garner R. Miller
ATP/CFII/MEI
Manchester, CT =USA=
Old June 14th 04, 05:43 PM
EDR
In article , Garner Miller
In article , EDR
Sounds like TCAS
encoding at all.
Okay, TCAS I vice TCAS II. Everyone should specify.
Old June 15th 04, 01:38 AM
BTIZ
you did not specify...
BT
Transponder test after static system opened? Jack I Owning 6 March 14th 04 03:09 PM
Fixing the Transponder with Duct Tape and Aluminum Foil Ron Wanttaja Home Built 45 March 14th 04 12:18 AM
