In article , Garner Miller
wrote: In article , EDR wrote: Sounds like TCAS TCAS only works with Mode-S transponders. Who told you that? A Mode C transponder looks the same on a TCAS screen as Mode S. The only difference is that two Mode-S-equipped airplanes are able to coordinate a TCAS maneuver (so both airplanes won't get told "climb" and climb into each other). TCAS will interact and with Mode C transponders just fine, and will even show and give a traffic advisory for aircraft with no altitude encoding at all. Okay, TCAS I vice TCAS II. Everyone should specify. |
you did not specify... BT |
Transponder test after static system opened? | Jack I | Owning | 6 | March 14th 04 03:09 PM |
Fixing the Transponder with Duct Tape and Aluminum Foil | Ron Wanttaja | Home Built | 45 | March 14th 04 12:18 AM |
