How does a Prop Governor work?
Old September 4th 04, 06:57 PM
Eduardo Kaftanski
Felix wrote:
Hi,
I was wondering if anyone can explain exactly how a prop governor
works for a constant speed prop system? All I know is that the engine
Oil pushes a piston in the prop hub that twists the prop to the
appropriate angle.
most governors work the same way... rotation moves a set of weights
that move a valve that lets oil through.
in case of a single engine plane prop, the governor lets more oil through
as the RPMS go up to rotate the blades and increase pitch.
Eduardo Kaftanski |
| Freedom's just another word
http://e.nn.cl | for nothing left to loose.
Right prop, wrong prop? Wood prop, metal prop? Gus Rasch Aerobatics 1 February 14th 08 10:18 PM
Ivo Prop on O-320 Dave S Home Built 14 October 15th 04 03:04 AM
Prop Pitch Question Eugene Wendland Home Built 2 April 25th 04 03:22 AM
IVO props... comments.. Dave S Home Built 16 December 6th 03 11:43 PM
Metal Prop vs. Wood Prop Larry Smith Home Built 21 September 26th 03 07:45 PM
