Jim,
What do folks think of this procedure? Can it harm the engine? Good procedure. You cannot harm an engine by leaning it during taxi. You might want your mechanic to adjust idle mixture. If, at idle, you pull out the mixture slowly, you should see a 25 to 50 rpm rise in RPM just before the engine quits - that's the correct setting. OTOH, if you adjust it for your field altitude, you might have problems at lower altitude fields. -- Thomas Borchert (EDDH) |
Ground speed control with leaning | Roger Long | Piloting | 11 | June 8th 04 09:22 PM |
Leaning / step climbing? | aaronw | Piloting | 30 | November 17th 03 05:44 PM |
O-320 leaning | Roger Long | Piloting | 5 | November 8th 03 11:40 PM |
Leaning with EGT? | Chris W | Home Built | 3 | September 18th 03 07:28 PM |
More About Leaning During Climb | Dan Luke | Owning | 13 | July 11th 03 02:36 PM |
