Weight and Balance Formula, Can one calculate the envelope
Old September 29th 04, 04:28 AM
Excel uses only an IF statement. I have used it in an unrelated large
scale water flow situation, but found it messy to use. I was thinking
that a series of them could be used to end up with a yes (OK) or no
answer, but I like your concept better of showing where you are on the
actual CG/GW range.
In addition you could show the effect of burning off fuel as a line.
I don't think any 172s will present a problem in this area, but some
others like Bonanzas can.
My experience is that it is hard to exceed the CG range of a 172, but
easy to exceed the gross weight.
Old September 29th 04, 08:15 AM
Peter Duniho
om...
Most likely because you are not sufficiently familiar with Excel. The fact
that you think that "Excel uses only an IF statement" supports this
likelihood. It has hundreds of worksheet functions, not counting all of the
add-ins that provide even more functionality.
I don't know what calculations are involved in a "large scale water flow
situation", but I doubt it really required exclusive use of nested IF
statements.
You could draw a line, but why bother? All you really need are the two
end-points. I've never seen a W&B graph that had a convex curve, which
would be required to allow the takeoff and landing weights to fall inside
the envelope, while still having an intermediate state outside the envelope.
Pete
172S Weight and Balance Question David J Piloting 9 March 23rd 04 01:08 AM
Weight and Balance JP Piloting 2 January 13th 04 10:54 AM
Weight & Balance Question Harry Gordon Piloting 28 December 30th 03 01:51 AM
RV-7a baggage area David Smith Home Built 32 December 15th 03 04:08 AM
Weight and balance question. Wayne Piloting 5 November 28th 03 06:45 PM
