Probably differential pressure across an orifice. These transducers are now
very inexpensive, except in the aviation market. Rod "CVBreard" wrote in message ... According to the Cessna factory parts book, the original equipment gauge is fed by a pressure transducer. ----------------------------------------------------------- Which is measuring the pressure of ______________? |
That is a valid and accurate way of measuring flow, almost as accurate
as a turbine meter and has less to go wrong. The same method is used to meter large water flows from water plants and into large plants. |
Is Your Airplane Susceptible To Mis Fu eling? A Simple Test For Fuel Contamination. | Nathan Young | Piloting | 4 | June 14th 04 06:13 PM |
Cessna 150 Long Range Fuel Tank Install | Ted Timmons | Owning | 3 | May 16th 04 08:06 PM |
Cessna 172 with Wild Fuel Gauge Needle | jls | Owning | 26 | February 20th 04 05:56 AM |
Yo! Fuel Tank! | Veeduber | Home Built | 15 | October 25th 03 02:57 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
