Incidentally, what's a "stress riser?"
A stress riser is any flaw in a structural piece that concentrates the stresses through that area to the point that failure might occur. A common example is cutting glass. The "cutter" doesn't cut; its small roller causes a shallow crack in the glass that will allow you to break the glass cleanly when it's bent. On a propeller a nick intereferes with the lines of force in the blade, causing them to have to bend around the nick and so concentrating them below the damage. Their concentration can start the propeller cracking. The blade undergoes huge G forces outward, thrust forces forward, and drag forces chordwise; a prop is often the most heavily stressed part on the whole airplane, and I often see chewed-up props on otherwise cared-for airplanes. Owners don't understand the risks. A prop that throws a foot or so of blade is liable to tear the engine out of the mounts before the pilot can get it stopped, and guess what happens to the CG when about 300 pounds of engine and prop leave a 172? The airplane can't even glide. I demonstrate the stress riser phenomenon to my class using strips of light aluminum flashing. The students try (unsuccessfully) to tear a piece of the flashing. Then I file a tiny nick in the edge, and it tears easily. A second piece with a nick dressed out becomes impossible to tear. Dan |
airplane, From an engineering standpoint - A light plane propeller, whether wood or aluminum, is about 1/8 inch larger in diameter at cruise than when standing still due to centrifugal acceleration. Consider also that a prop is an essential non-redundant monolithic structure, which if aluminum, is made of a material (2024-T3) that has good tensile, but mediocre fracture toughness properties. In operation it is subject to very high-cycle bending fatigue due to torsional resonances. Fracture toughness is a measure of the crack propagation resistance of a material. As a fracture toughness example, compare the tensile strength of cellophane vs shrinkwrap with and without a tiny transverse slot cut into it. Props are highly stressed and must not be treated casually. |
Consider also that a prop is an e=ADssential
non-redundant monolithic structure, which if aluminum, is ma=ADde of a material (2024-T3) that has good tensile, but mediocre fract=ADure toughness properties. Lightplane props are universally made of 2025T6, according to my Sensenich prop manual. 2024T3 is used mostly for aircraft skins. The 2025 lacks the manganese and magnesium of the 2024, but has silicon that the 2024 doesn't have. The yield and tensile strengths of 2025T6 are a bit less than 2024T3, but the metal isn't as hard, likely reducing crack tendencies somewhat. The copper is still present, making the prop corrosion-prone, and in Canada, at least, we have to remove the prop, strip it and inspect it for corrosion at least every five years. Corrosion pits can be as bad as nicks for starting cracks. Dan |
![]() Lightplane props are universally made of 2025T6, The drawing I saw was 2024 (& I recalled T3) but it was not a Sensenich drawing. I never heard of 2025 before, though since they are a forged blank, they could create any alloy........ I originally thought they used 2017. |
Right prop, wrong prop? Wood prop, metal prop? | Gus Rasch | Aerobatics | 1 | February 14th 08 10:18 PM |
Ivo Prop on O-320 | Dave S | Home Built | 14 | October 15th 04 03:04 AM |
IVO props... comments.. | Dave S | Home Built | 16 | December 6th 03 11:43 PM |
Metal Prop vs. Wood Prop | Larry Smith | Home Built | 21 | September 26th 03 07:45 PM |
fatal bird strike | StellaStar | Piloting | 9 | July 13th 03 09:41 PM |
