practical best range application?
Old February 1st 05, 07:44 PM
Kurt R. Todoroff
Wouldn't it simply be your airplane's best glide speed?
It would be the same AoA, but not necessarily the same speed. This speed
also varies with density altitude and weight.
hmm, AoA... Well just off the top of my head here, someone please correct
me if I'm wrong...
Stall speed, of course, also depends on AoA, not speed. So, if you have
an idea what stall speed does at different weights & density altitudes,
best glide speed should follow the same curve. Best glide is the point at
which overall drag is lowest, so it stands to reason it's also where max
range would be. If you can't avoid a headwind you may need to speed up a
bit to get the best ground speed per fuel burn, but that's a simple
calculation using ground speed & a close estimate of fuel burn.
So it seems, in practice, one should be able to get really close to max
range speed very quickly without any complicated calculations.
-Dan
You are correct in your implicit suggestion that these airspeeds are based upon
angle-of-attack. Maximum range glide speed and maximum endurance speed are the
same since they both occur at (C_L/C_D)max AOA. However, your statement, " . .
.. so it stands to reason it's also where max range would be . . . " is
incorrect. Maximum range speed occurs at ((C_L)^1/2 / C_D)max AOA. Thus, it
is higher than (C_L/C_D)max airspeed. Maximum range and maximum endurance
airspeeds do not occur on the same point on the performance chart.
Kurt Todoroff
Markets, not mandates and mob rule.
Consent, not compulsion.
Old February 2nd 05, 03:35 AM
steve.t
The original question mentioned that one airport has been blown-up and
another is unusable for some reason. If this kind of attack was going
on, if I were running the GPS network, I'd turn it off.
Depending on the damage that has been done, VORs may well be dead.
And since the original poster appears to me to be from Australia, they
probably use more ADF equipment than we do here in the USofA. But my
original comments were geared more toward the mentality of the
HSA/TSA/FBI/FAA and what they would decide to do.
Later,
Steve.T
PP ASEL/Instrument
Old February 3rd 05, 11:50 PM
David CL Francis
On Tue, 1 Feb 2005 at 19:44:36 in message
, Kurt R. Todoroff
This interests me. Can you point me to the maths that produces this
result? I cannot see at the moment why maximum range should not occur
at maximum lift/drag: apart from some smaller effects like the effect of
engine thrust on lift etc. and any effects where engine and/or propellor
efficiency has a significant effect.
Maximum endurance for a glider occurs at minimum sinking speed which is
normally closer to the stall AoA than maximum Lift/Drag. Maximum range
for a glider occurs at maximum Lift/Drag as you say (I think that's what
you mean), but maximum endurance does not, as far as I can see.
I presume the calculation assumes a linear relation between AoA and CL?
Your last sentence in your paragraph above, with which I agree, seems to
contradict your second sentence.
David CL Francis
Old February 4th 05, 09:51 PM
Kurt R. Todoroff
, Kurt R. Todoroff
upon
it
David CL Francis
Hi David,
I did a Google search on the contiguous string "maximum range airspeed". You
must include the quotation marks. Google returned many websites. The first
one:
http://www.eaa1000.av.org/technicl/p...s/perfspds.htm
is excellent.
In the section titled "Performance Charts", notice that maximum range airspeed
and maximum endurance airspeed occur at different locations on the drag polar.
This is a function of AOA. Also notice the language "To maximize the
endurance, we want to maximize the amount of time that we can stay in the air."
Whether you want to maximize your aircraft's endurance (time) during powered
flight or in a power-off gliding descent (even in a glider), the principal is
the same. You want to operate the aircraft at an airspeed that corresponds to
(C_L/C_D)max. This is not close to the stall angle of attack.
My two sentences in question are consistent.
I hope that the link that I provided helps.
Best wishes.
Kurt Todoroff
Old February 4th 05, 11:01 PM
xerj
I'm confused too.
This is the sentence:-
"Maximum range glide speed and maximum endurance speed are the
same since they both occur at (C_L/C_D)max AOA."
How can they be "the same" when they occur at two different points on the
power curve?"
Old February 6th 05, 11:48 PM
David CL Francis
Hi Kirk,
I did look at that site and it is jolly and the rough equations are
correct but presented perhaps as more complicated than they need be.
Leaving out some constants:
Power = drag( or thrust) x velocity.................................(1)
Velocity =
distance/time.............................................. ..(2)
Total Energy = thrust (or drag) x distance travelled...........(3)
equivalent to total fuel used.
Since from (2) distance = velocity x time.
(3) can be re-written as energy = thrust x velocity x time
which is the same as
Total energy = Power x
time............................................(4 )
Fuel used is SPC x time x power
Fuel used = SPC x time x thrust x velocity
Fuel used = SPC x time x thrust x distance /time
Fuel used = SPC x thrust x distance..................................(5)
Therefore since SPC is a constant then (5) is equivalent to (3).
Now this will change with time as fuel is burned up this effect is
significant on long range airliners because the required lift = weight.
So calculating the range does require an integration but at all times
the drag (and thrust) will be least when the aircraft flies at Maximum
Lift drag ratio because it will then be the least fraction of the
weight.
So you fly at maximum Lift/Drag and get maximum range. As you fly you
adjust your speed to stay at maximum Lift/Drag.
This seems in agreement so far with the WEB site that you quoted.
However I have a little difficulty getting my head around the 'optimum
cruise' that the site goes on to deal with.
The actual graph of power against velocity does show the minimum value
of power/velocity clearly.
Quoting from the Web site:
He gets to
[(lb of fuel)/nm proportional to Power/V]]
All OK but I am now going to use V for speed, Time for hours and dist
for distance.
Now our friend goes on to decide that fuel flow per unit V is the right
parameter for optimum cruise speed.
Why is that an optimum cruise?
He starts with lb of fuel per distance as proportional to Power/V
But what is Power/V? Nothing more than thrust again which is also drag.
And the left hand side can be changed by letting dist = V x time
Now we have (lb of fuel)/(V x time) proportional to thrust
Now he divides by V again to get (cancelling a bit)
(lb of Fuel)/time proportional to Thrust/V
So in effect he is finding the 'optimum' of (lb of fuel per hour) in
terms of thrust per knot. Why is that an optimum?
Hmm. First sentence: "Maximum range glide speed and maximum endurance
speed are the same since they both occur at (C_L/C_D) Maximum AOA."
Second sentence: "Maximum range and maximum endurance
airspeeds do not occur on the same point on the performance chart."
Those do not mean the same thing to me. Combine the two and we have that
the speeds are the same but do not occur at the same place on the
performance chart. How could that be? It seems to me that the first
sentence is wrong - Maximum range glide speed and maximum endurance
speed are NOT the same as is confirmed on the Web site.
It did - up to a point!
E&OE
David CL Francis
TSA requirement of Security Awareness Training dancingstar Piloting 3 October 5th 04 02:17 AM
This week's AW&ST: apparently THAAD will have some ABM (as in anti- *ICBM*) capability. Scott Ferrin Military Aviation 29 August 31st 04 04:20 AM
Helicopter gun at LONG range Tony Williams Naval Aviation 3 August 20th 03 02:14 AM
To Steal an F-86 Dudley Henriques Military Aviation 19 August 1st 03 02:26 AM
