Sent: Friday, February 04, 2005 1:57 PM Ron McKinnon wrote: From: "Matt Whiting" Ron McKinnon wrote: "Matt Whiting" wrote in message ...Why? It is acceptable to "polish the frost smooth" per FAR 91.527. Interesting. It seems a rather dubious practice to me. It would indeed appear to be legal in the US - but, FWIW, it isn't legal in Canada. Why? Smooth frost is less of an aerodynamic issue that a thick layer of dirt, bugs and dust... Be that as it may, arguing that its not as bad as something else (that you shouldn't fly with either), isn't any argument at all for the acceptability of flying with smooth frost. Frost, smooth or otherwise, or other contaminants arguably affect the aerodynamic behaviour. How much does it change with a given level of contamination?, what level of contamination is significant? or how significant is such a change? how much is too much? how smooth is smooth enough? in what way will such change affect the aerodynamic behaviour of the plane? (does it change the critical angle of attack for the wings? the control surfaces?, what are the new critical angles (what's the new stall behaviour? is a tailplane stall more likely? will it spin easier? how does it change rudder effectiveness?) for instance) are critical questions. But these are not questions that a typical pilot is in a position to answer operationally. This a job for computer simulations, and lab analysis in controlled test conditions, and for test pilots in controlled test situations. They only affect the aerodynamic behavior if they significantly affectt he flow in the boundary layer. On some airfoils this a concern with fairly small disturbances, but on others it isn't much of a concern at all. Saying that you should not fly an airplane that has any frost on it is just as silly as saying you should never take off with less than full fuel. You have to know your airplane, nobody is arguing that. Most light airplanes will fly just fine with polished frost on the wings and even the control surfaces, I know my 182 did. The issue isn't whether it will fly at all, but what happens to its flying characteristics, and whether you're still operating with safe margins for error. A few anecdotal cases where it 'flew', does nothing to answer that. There are many other cases on record where it didn't. What, exactly is the expected level-flight stalling speed with this particular amount of frost, 'polished' to this particalar smoothness? Is it safe with the current loading, the current density altitute, the current runway (the destination loading, density altitude, and runway?) - do you have any safety margin left? or have you used it all up by leaving frost on the wings? or have you, in these particular circumstances not affected it at all? What's the new stalling characteristics of the stablizers, elevator and rudder effectiveness. Are you going to be in the neigborhood of a tailplane stall on takeoff? Is the frost layer uniform - does it affect the whole wing in the same way? You don't know. . And its not just about 'knowing your airplane'. How many pilots can say with assurance how much contamination will significantly affect the flow in the boundary layer?, or for which airfoils its a concern with fairly small disturbances? There are no doubt some that can, I'll grant you. But this is not the usual rule. (Off the top of your head - What is the airfoil on your 182? How sensitive is it to contamination. How much contamination is too much on your 182. What thickness of frost is too much for this airfoil? How 'smooth' *does* it have to be? And then what about the stabilizers, elevators and rudder? Exactly what is the new level flight stalling speed?) The proposition isn't that you shouldn't fly an airplane that has *any* frost on it - it is that you shouldn't fly it with any frost on the critical surfaces: wings, stabilizers, rudder (propellers). It is obviously 'legal' in the US (the original FAR citation shows this), so in the US you may obviously feel free to use your discretion in the matter. But that doesn't necessarily mean it is safe. In other places (Canada, for instance) it isn't even legal. |
Ron McKinnon wrote:
From: "Matt Whiting" Sent: Friday, February 04, 2005 1:57 PM They only affect the aerodynamic behavior if they significantly affectt he flow in the boundary layer. On some airfoils this a concern with fairly small disturbances, but on others it isn't much of a concern at all. Saying that you should not fly an airplane that has any frost on it is just as silly as saying you should never take off with less than full fuel. You have to know your airplane, nobody is arguing that. Most light airplanes will fly just fine with polished frost on the wings and even the control surfaces, I know my 182 did. The issue isn't whether it will fly at all, but what happens to its flying characteristics, and whether you're still operating with safe margins for error. A few anecdotal cases where it 'flew', does nothing to answer that. There are many other cases on record where it didn't. My 182 flew just fine. I'm not aware of any 182 accidents from polished frost and I know many people with many thousands of hours operating 182s in my area and climate. What, exactly is the expected level-flight stalling speed with this particular amount of frost, 'polished' to this particalar smoothness? Is it safe with the current loading, the current density altitute, the current runway (the destination loading, density altitude, and runway?) - do you have any safety margin left? or have you used it all up by leaving frost on the wings? or have you, in these particular circumstances not affected it at all? What's the new stalling characteristics of the stablizers, elevator and rudder effectiveness. Are you going to be in the neigborhood of a tailplane stall on takeoff? Is the frost layer uniform - does it affect the whole wing in the same way? You don't know. . Same way you don't know after you fly through a swarm of bugs. Does this freak you out also? It never bothered me. I can detect a stall pretty easily in all of the airplanes I've flown. If the stall commences at 60 knots instead of 50 knots, I don't really care, I just stay above that airspeed. And its not just about 'knowing your airplane'. How many pilots can say with assurance how much contamination will significantly affect the flow in the boundary layer?, or for which airfoils its a concern with fairly small disturbances? There are no doubt some that can, I'll grant you. But this is not the usual rule. (Off the top of your head - What is the airfoil on your 182? How sensitive is it to contamination. How much contamination is too much on your 182. What thickness of frost is too much for this airfoil? How 'smooth' *does* it have to be? And then what about the stabilizers, elevators and rudder? Exactly what is the new level flight stalling speed?) I don't care exactly what it is as I mentioned above. The stall speed varies constantly with loading and many other factors. If you fly based on what the ASI tells you and not what the airplane is telling you, then you are going to be a statistic some day. The proposition isn't that you shouldn't fly an airplane that has *any* frost on it - it is that you shouldn't fly it with any frost on the critical surfaces: wings, stabilizers, rudder (propellers). And I disagree with that proposition and have done so successfully for 27 years. It just requires a little common sense and discussion with people who have a lot of experience in your make and model. It is obviously 'legal' in the US (the original FAR citation shows this), so in the US you may obviously feel free to use your discretion in the matter. But that doesn't necessarily mean it is safe. It is legal and safe if done properly. Just like most other aspects of aviation. However, I'm not suggesting you should do it. I'm just saying that for many of us it isn't a big deal. In other places (Canada, for instance) it isn't even legal. Then you shouldn't do it in Canada. Matt |
Challenger Crashe at TEB | Jon Kraus | Owning | 78 | February 11th 05 01:10 AM |
Need details on a Challenger 602 | Bob Moore | Piloting | 14 | December 6th 04 08:28 PM |
Challenger forum | Dico Reyers | Home Built | 0 | December 30th 03 06:48 PM |
Ignoring the Challenger? | robert arndt | Military Aviation | 0 | July 1st 03 10:24 AM |
