Proper Torque for Fuel Fittings
Old February 13th 05, 09:45 PM
Steve Waltner
Default Proper Torque for Fuel Fittings
I'm to the point of installing the fuel fittings on the fuel tanks on
my RV-8A project. I'm a little confused about what torque to set my
wrench at when installing the fitting.
The fitting that goes through the tank rib and 3/16" reinforcement
plate is an AN833-6D elbow with an AN924-6D nut on the outside. There
are also a pair of -4D fittings for the vent line which will soon be
mounted as well. The only torque chart that I'm ever able to find is
one for AN bolts/nuts. Since these are aluminum fittings, I don't dare
torque them to the same values.
Any assistance would be greatly appreciated.
Steve
Old February 13th 05, 10:20 PM
Juan Jimenez
I was taught to use no more than 10-12 ft/lb of torque for AN aluminum
fittings, but why not call Van's to get the answer from the source?
"Steve Waltner" wrote in message
Steve
Old February 13th 05, 11:46 PM
Morgans
Steve
This is such basic information, I don't know why anyone needs to ask stuff
like this.
Everyone knows, you tighten it until it strips, then back off 1/4 turn.
I'll go back to my room, now. g Sorry, I had to do it!
Jim in NC
Old February 14th 05, 12:25 AM
Blueskies
"Steve Waltner" wrote in message ...
Steve
Look up MS21344, should get you there...
Old February 14th 05, 12:47 AM
Blueskies
"Blueskies" wrote in message m...
Steve
http://assist.daps.dla.mil/quicksearch/
Old February 14th 05, 03:12 AM
Steve: I've got the torque charts at work and will pass on the correct
numbers when I get in. The torque values are different for the various
size fittings, with type of service and fitting material both having an
impact on the value.
Craig C.
Old February 14th 05, 03:25 AM
Managed to locate the set that I had at home.
#6 Bulkhead nut is 75 inch-pounds +/- 5% for clean and dry threads.
#4D nuts get 75 inch-pounds +/- 5% also
Craig C.
Old February 14th 05, 07:45 AM
John
Steve
That's a lot of difference between 75 in pounds and 120-144 inch pounds
(10-12 ft/pounds). Definetly check with Van's but if you can't wait go with
the more conservative. (i'd wait!)
John
Old February 15th 05, 12:42 PM
Juan Jimenez
"John" wrote in message
Steve
with
John
Yes, it is, which is one reason I told him to call Van's and ask and get it
from the source.
Old February 16th 05, 12:05 AM
Blueskies
"Blueskies" wrote in message . com...
Steve
http://assist.daps.dla.mil/eAccess/l...8/83/40046.PD9
See if that works...
Torque values for oil screen John Clonts Owning 2 January 25th 05 12:01 AM
Fuel pump fittings Evan Carew Home Built 15 October 3rd 04 03:13 AM
