The Civil Air Patrol purchased 15 tricycle gear Maule 235s for towing
and search and rescue. I have both towed and been towed by this aircraft with excellent results in both club ships and the CAP's Blanik L-23. Visibility in the CAP's Maule is good, but they have the observation options including glass doors and overhead panels. Mirrors are mounted inside below the observation panels. CAP did have a mod added for additional cooling--and even then the oil temp gauge shows very high readings. Adding a an accurate digital oil and CHT gauge, however, shows the factory installed analog gauges to be reading far higher than actual temperatures. I would prefer the conventional gear Maule for towing--but the Tri gear works well on a grass field as well. Might note that this is all in the east--but at temperatures up to the mid 90s. Good luck-- |
I tow with one of the CAP 235 Maules. It does a good job pulling a
gross weight L-23. At 75mph with one notch of flaps on 1500 to 2000 density altitude day you will see climb rates of 600 to 700ft/min. with full power. Digital oil temps hover around 195 to 200 degrees and cylinder head temps. run in the 1300 to 1400 degree range so no cooling problems with the added cooling skirt. Negatives: Crummy visibility over the nose at 75mph with one notch of flaps. Worse with no flaps and comfortable speeds are too high without flaps (Vy=90mph) . Visibility elsewhere is great with the observation windows/doors/greenhouse. LOW useful load. With me and full tanks (including aux's) I can carry 148 additional pounds. Needless to say we keep the aux's empty. Figure 13.5 to 14 gph. No arm rest and it is a control wheel instead of stick. Shoulders get tired. Low flap operating range, so you have to dump the flaps before starting down and the flap operating handle sucks! Difficult to disengage lock and easy to break. CAP ones have Tost hook which I feel is much safer if someone "kites" Door latches and window latches are cheesy to say the least. All in all, not a bad airplane, especially for a occassional tow, but I sure like the Pawnee better if you are going to do many tows. -Deputy Dog |
We have had reason for contests or safaris to use two different
Maule models for a supplemental tug over the years. High experience towpilot and taildragger drivers. Pawnees, 180s, Cubs. His comments were that the M-5 taildragger actually handled the transition to landings nicer than the M-7. The roll authority coupled with flap interactions were not as nice in hot, gusty days in the M-7. Otherwise, the other fellows gave you a lot more data. Cindy B www.caracolesoaring.com (Deputy Dog) wrote in message . com... I tow with one of the CAP 235 Maules. It does a good job pulling a gross weight L-23. Door latches and window latches are cheesy to say the least. All in all, not a bad airplane, especially for a occassional tow, but I sure like the Pawnee better if you are going to do many tows. -Deputy Dog |
Maule SFSA Tailwheel Information | Ron Wanttaja | Home Built | 1 | May 28th 04 12:47 PM |
Maule aircrafts | 7000 | Piloting | 1 | October 19th 03 07:43 PM |
Maule aircrafts | 7000 | General Aviation | 0 | October 19th 03 04:47 PM |
paging Maule Driver | David Hill | Owning | 0 | September 28th 03 04:58 AM |
Maule Turbine | kevin | Owning | 16 | August 4th 03 10:49 PM |
