Battery capacity checker
Old October 20th 03, 04:06 PM
Peter Nyffeler
In article , "Roger Druce" wrote:
Perhaps someone out in r.a.s land may be able to point me in the direction
of a commercial piece of equipment which would perform the following task.
I would like to be able to charge up a 12 volt (nominal) gell cell battery
and then plug it into a piece of equipment to check its total AmpHour
capacity during discharge at some constant rate current (say the "10 hour"
rate or the "20 hour" rate). All this towards assessing whether the battery
has proven useful capacity and life left in it, or has it reached its
discard date?
The equipment would show the delivered amp-hours up to the point at which
the voltage has fallen to a nominated end voltage.
I realise that you can do it in a way with a light globe to discharge the
battery and then time the length the light holds up glowing brightly. This
is all too primative for this day and age, and there ought to be some piece
of equipment available for the task.
Or some circuit from an electronics hobby magazine??
Thanks in antcipation.
Roger Druce
I built one myself.
You find the schematic at http://www.ppc.ethz.ch/~peny/sf/ah_test.html
Peter Nyffeler
Tel P 01 363 62 42, Tel G 01 632 43 60, Fax G 01 632 10 21
Old October 20th 03, 11:02 PM
John Giddy
Hi Peter,
Good circuit !
However I have a couple of questions:
1.
I presume the FET (Q2) will need a heatsink, as it will
dissipate approximately 12W when discharging at 1 Amp ?
2.
R9 should be 470 ohm, not 470 K
Cheers, John G.
"Peter Nyffeler" wrote in
message ...
| In article
, "Roger
in the direction
the following task.
gell cell battery
total AmpHour
(say the "10 hour"
whether the battery
reached its
| discard date?
the point at which
to discharge the
| Roger Druce
| I built one myself.
| Peter Nyffeler
Old October 21st 03, 08:57 AM
Peter Nyffeler
In article , "John Giddy" wrote:
Hi Peter,
Good circuit !
1.
2.
Cheers, John G.
John you are right.
The FET needs a heatsink, as it works as a variable power resistor to provide
a constant discharge current
And R9 should have 470 ohm to turn on the monitor LED.
Thanks
Peter
Peter Nyffeler
Old October 22nd 03, 09:10 AM
John Giddy
Another question on Peter Nyffeler's circuit:
I think the part number for the dual operational amplifier
is wrong. It should read "LM358" NOT "LM385". This last
item is a precision voltage reference, not an amplifier.
Cheers, John G.
"John Giddy" wrote in message
| Hi Peter,
| Good circuit !
| 1.
| 2.
| Cheers, John G.
| message ...
| | In article
| , "Roger
me
| in the direction
| the following task.
(nominal)
| gell cell battery
| total AmpHour
| (say the "10 hour"
assessing
| whether the battery
it
| reached its
| | discard date?
| the point at which
globe
| to discharge the
| | Roger Druce
| | I built one myself.
| | Peter Nyffeler
21
RG Battery Charger by Jim Weir in Kitplanes Kevin O'Brien Home Built 4 January 6th 05 01:19 AM
Batteries, charger for Yaesu handheld - NiCad or NiMH? David Herman Owning 10 November 7th 04 04:30 PM
Battery Replacement and Cold Cranking Amps O. Sami Saydjari Owning 27 February 2nd 04 02:38 PM
Icom A5 Battery Tester ?? Harry Gordon Piloting 5 January 10th 04 01:29 PM
Battery life...how to test? Jim Kelly Soaring 2 July 11th 03 09:12 PM
