Battery capacity checker
Old October 21st 03, 08:57 AM
Peter Nyffeler
In article , "John Giddy" wrote:
Hi Peter,
Good circuit !
However I have a couple of questions:
1.
I presume the FET (Q2) will need a heatsink, as it will
dissipate approximately 12W when discharging at 1 Amp ?
2.
R9 should be 470 ohm, not 470 K
Cheers, John G.
John you are right.
The FET needs a heatsink, as it works as a variable power resistor to provide
a constant discharge current
And R9 should have 470 ohm to turn on the monitor LED.
Thanks
Peter
Peter Nyffeler
Tel P 01 363 62 42, Tel G 01 632 43 60, Fax G 01 632 10 21
RG Battery Charger by Jim Weir in Kitplanes Kevin O'Brien Home Built 4 January 6th 05 01:19 AM
Batteries, charger for Yaesu handheld - NiCad or NiMH? David Herman Owning 10 November 7th 04 04:30 PM
Battery Replacement and Cold Cranking Amps O. Sami Saydjari Owning 27 February 2nd 04 02:38 PM
Icom A5 Battery Tester ?? Harry Gordon Piloting 5 January 10th 04 01:29 PM
Battery life...how to test? Jim Kelly Soaring 2 July 11th 03 09:12 PM
