Another question on Peter Nyffeler's circuit:
I think the part number for the dual operational amplifier is wrong. It should read "LM358" NOT "LM385". This last item is a precision voltage reference, not an amplifier. Cheers, John G. "John Giddy" wrote in message ... | Hi Peter, | Good circuit ! | However I have a couple of questions: | | | 1. | I presume the FET (Q2) will need a heatsink, as it will | dissipate approximately 12W when discharging at 1 Amp ? | | 2. | R9 should be 470 ohm, not 470 K | | Cheers, John G. | | "Peter Nyffeler" wrote in | message ... | | In article | , "Roger | Druce" wrote: | | Perhaps someone out in r.a.s land may be able to point me | in the direction | | of a commercial piece of equipment which would perform | the following task. | | | | I would like to be able to charge up a 12 volt (nominal) | gell cell battery | | and then plug it into a piece of equipment to check its | total AmpHour | | capacity during discharge at some constant rate current | (say the "10 hour" | | rate or the "20 hour" rate). All this towards assessing | whether the battery | | has proven useful capacity and life left in it, or has it | reached its | | discard date? | | | | The equipment would show the delivered amp-hours up to | the point at which | | the voltage has fallen to a nominated end voltage. | | | | I realise that you can do it in a way with a light globe | to discharge the | | battery and then time the length the light holds up | glowing brightly. This | | is all too primative for this day and age, and there | ought to be some piece | | of equipment available for the task. | | | | Or some circuit from an electronics hobby magazine?? | | | | Thanks in antcipation. | | Roger Druce | | | | I built one myself. | | You find the schematic at | http://www.ppc.ethz.ch/~peny/sf/ah_test.html | | | | Peter Nyffeler | | Tel P 01 363 62 42, Tel G 01 632 43 60, Fax G 01 632 10 21 | |
RG Battery Charger by Jim Weir in Kitplanes | Kevin O'Brien | Home Built | 4 | January 6th 05 01:19 AM |
Batteries, charger for Yaesu handheld - NiCad or NiMH? | David Herman | Owning | 10 | November 7th 04 04:30 PM |
Battery Replacement and Cold Cranking Amps | O. Sami Saydjari | Owning | 27 | February 2nd 04 02:38 PM |
Icom A5 Battery Tester ?? | Harry Gordon | Piloting | 5 | January 10th 04 01:29 PM |
Battery life...how to test? | Jim Kelly | Soaring | 2 | July 11th 03 09:12 PM |
