On 31 Oct 2003 04:04:31 GMT, Andy Blackburn
wrote: I'm 5'9', 180 lbs. and I find the S-H 'a' models way too narrow - I had to twist my upper body sideways to fit between the canopy rails. There is both a height and width limit for these cockpits. For me it was width. Also look out for the high 'ape factor' requirement on S-H designs ('a' and 'b' models alike). I found I had to loosen the shoulder straps to reach the instrument panel - which was a problem with all the modern computer equipment demanding knob-twisting. Others with longer arms may not find this to be an issue. Some owners have installed panel extensions to deal with this. My advice: Don't buy a glider without at least sitting in one first. 9B Good advice. re the ape factor. This is removed if you wear a back pack parachute and sit on a very thin cushion. It really is comfortable and you can reach the panel. Some of us in Australia have modified the Ventus a seat pan to place your backside further forward. You can actually cut it in half and add 30mm and re-organise the front part. This helps if you are long in the body and have short legs. Mike Borgelt |
Who can identify this tube frame aircraft fuselage? | Rob de Bie | Home Built | 5 | January 13th 05 09:45 PM |
Trike wing bolt size | Aaron Smith | Home Built | 0 | September 30th 03 03:02 AM |
#1 Jet of World War II | Christopher | Military Aviation | 203 | September 1st 03 03:04 AM |
Long-range Spitfires and daylight Bomber Command raids (was: #1 Jet of World War II) | The Revolution Will Not Be Televised | Military Aviation | 20 | August 27th 03 09:14 AM |
Fitting canopy frame to fuselage advice | Deputy Dog | Soaring | 5 | July 27th 03 04:08 AM |
