Mark James Boyd wrote:
I suspect gliding is much more popular because petrol is so expensive and in some countries one must get a scheduled "slot" to fly a plane. I am deeply shocked to read this statement on r.a.s.! Soaring is popular here because it's a challenge and it's fun, while flying straight and level with the help of a fuel to noise converter is just plain boring. Don't the flight levels start at 6000 in some places too? Do you need radios for this? You're confusing flight levels with controlled airspace. Maybe it's the same in USA, but not here. Perhaps someone could tell us what radio requirements All our glider have radio. Not because it's required, but because it's a) convenient b) safe (on tow as well as on approach) c) allows team flying d) is required for cloud flying That it allows to enter controlled airspace is a nice side effect. Stefan |
Soaring in the US is a bit different (more basic?) than in Europe. A
lot of gliding is done at commercial operations, which usually do not bother to install radios (expense, battery maintenance, etc). Since this kind of flying is "show up, fly for an hour, go home", there is little sense of "ownership" in the gliders (which are often basic gliders like 2-33s or 1-26s, or various Blaniks) so they are not taken care of very well. There are exceptions, of course, usually where higher performance gliders are available. As far as US clubs, they also tend to be a lot more basic than European ones (sorry, I don't have any experience with SA/Oz/NZ so won't comment on them), so while radios are more common they are not universal. Private ships, however, are almost all equipped with radios - required for contests, anyway. When I fly commercial rides at the local glider operation, I carry a handheld, for all the obvious reasons mentioned by others, since only two of the 10 gliders available for rent or rides has a working radio - both single seaters. My own glider has a radio installed, as do all those of my gliding friends. Performance with a handheld is actually pretty good, especially from a glass ship. In a metal trainer, it helps to have an outside antenna. It always helps to hook up to a nice big battery. Then add a headset and push to talk velcroed to the stick - more wires than an astronaut! But better than no radio. We don't cloud fly much here (I know of only one pilot who does - in Florida), and controlled airspace is not really a problem - yet - so a pilot can get by for a long time never having to talk on the radio; and a lot do exactly that! I've even heard some express their opinion that they don't have a radio because they think a radio is unsafe in a glider - too distracting. As a result of lack of formal training in their correct use, radios are not used very well - way too much chatter and poor radio calls when needed (in the pattern, for example). Of course, this is not only a glider problem - if anything power pilots are worse! Oddly, most US pilots do not feel the need for a radio when aerotowing, but think it is necessary when winch launching - just the opposite of my experience. Cheers, Kirk 66 |
Stefan wrote:
Mark James Boyd wrote: I suspect gliding is much more popular because petrol is so expensive and in some countries one must get a scheduled "slot" to fly a plane. I am deeply shocked to read this statement on r.a.s.! Soaring is popular here because it's a challenge and it's fun, while flying straight and level with the help of a fuel to noise converter is just plain boring. Being cheaper and less hassle has nothing to do with it? ![]() I think here in the US lack of "hassle factor" is a big motivation. Here, we've seen the ultralight and hang gliding community boom while the glider population is decreasing. Some people (including me and Dennis Wright, our SSA chief) think this is because ultralights and hang gliders have practically a "0" hassle factor (no checkride, no signoffs, no minimum distance flown from people, no tail numbers, no radio skill, etc.). http://www.nickselby.com/articles/av...flyeurope.html seems to indicate petrol and rentals and taxes and landing fees and in some cases (Germany) scheduled slots are required for power pilots. I would expect that some potential power pilots are glider pilots in Germany because of less expense and hassle. A winch launch and then a free landing in an open field sounds better than lots of $$$$ and scheduling. Don't the flight levels start at 6000 in some places too? Do you need radios for this? You're confusing flight levels with controlled airspace. Maybe it's the same in USA, but not here. You are correct that I was mixing terminology. I should have simply asked "is there some altitude above which radios are required overseas?" and said "in the US, radios are only legally required above FL180 (about 18,000 feet), and also near busy airports (which are sparse in many parts of soaring country)." I think the definition of "controlled airspace" is best avoided, since in the US it doesn't directly concern radios ("E" airspace, for example). Perhaps someone could tell us what radio requirements All our glider have radio. Not because it's required, but because it's a) convenient b) safe (on tow as well as on approach) c) allows team flying d) is required for cloud flying That it allows to enter controlled airspace is a nice side effect. AHA! One huge difference is that cloud flying is more common in some places internationally. It is quite uncommon here in the US. Because of safety and convenience and team flying, as well as crew coordination and retrieves, I'd agree with the previous post that 95% of private and X-country capable gliders have radios installed. I think the main reason they aren't in many low-performance training gliders in the US is to keep them cheap, cheap, cheap. If it's not REQUIRED, it's an avoidable expense... |
Being cheaper and less hassle has nothing to do with it? ![]() .... I would expect that some potential power pilots are glider pilots in Germany because of less expense and hassle. A winch launch and then a free landing in an open field sounds better than lots of $$$$ and scheduling. Actually, it's the other way round. Gliding is *much* more hassle than flying noisemakers. Nevertheless, many pilots in our club have had a power license, too. Most of them let it expire and fly gliders only, despite the hassle. It's simply more fun. You're correct in one point: Power flying is expensive in Europe, and soaring is cheaper. But then, we don't want to occupy foreign countries to secure a cheap oil supply, and Kyoto means something to us. You are correct that I was mixing terminology. I should have simply asked "is there some altitude above which radios are required overseas?" Depends on the country. In my region, ist's 10'000 ft AMSL over flat land and 15'000 ft AMSL or 2000 ft AGL (whichever is higher) over the mountains. This is enough except if you want to enter wave, which doesn't happen too often. I think the definition of "controlled airspace" is best avoided, since in the US it doesn't directly concern radios ("E" airspace, for example). Got me! Stefan |
I think here in the US lack of "hassle factor" is a big motivation. Here, we've seen the ultralight and hang gliding community boom while the glider population is decreasing. Some people (including me and Dennis Wright, our SSA chief) think this is because ultralights and hang gliders have practically a "0" hassle factor (no checkride, no signoffs, no minimum distance flown from people, no tail numbers, no radio skill, etc.). It's an enduring myth among sailplane pilots that hang gliding has a low hassle factor. I've talked to a number of former hang glider pilots who are now sailplane pilots, and they say it is often the reverse. The reasons will vary from place to place, but here are few from the last one I talked to: -get to hang glider site: no wind, no fly. -ruin a car/truck every four years driving over logging roads to site -every cross country flight is a retrieve -glider depreciates quickly -leave home early, get home after dinner, wife grumpy -very tiring to fly Now he's flying a Ka-6: -leave home after lunch, home by dinner, wife ecstatic -easy drive to airport on paved roads; car still good -hugely better performance -long cross-country flights end back at airport -glider worth more now than when he bought it -relaxing to fly So, plenty of hassles, but different ones. And, unfortunately, the hang gliding community, at least in the US, is not growing either. -- ----- change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
Eric Greenwell wrote:
It's an enduring myth among sailplane pilots that hang gliding has a low hassle factor. I've talked to a number of former hang glider pilots who are now sailplane pilots, and they say it is often the reverse. The reasons will vary from place to place, but here are few from the last one I talked to: -get to hang glider site: no wind, no fly. -ruin a car/truck every four years driving over logging roads to site -every cross country flight is a retrieve -glider depreciates quickly -leave home early, get home after dinner, wife grumpy -very tiring to fly One of my three partners in a plane got started flying in a hang glider when he was 15. He bought it for $50. He'd haul it up a hill and fly down a few feet off the ground. One day his buddies egged him into taking it up a big hill with wind going up it. He took a few steps, and bingo, he was up for about a minute, and landed next to his house. He took it up a big hang gliding hill one time and the locals said "where's your battens?" He said "what are those?" so they laughed him off the hill... The same guy recently got me up in his ultralight. Incredible view, super low stall speed, VERY few restrictions in part 103. We flew right over the beach and waved at people. The engine was started with a tug of a rope. To be legal to carry passengers, one must become an ultralight "basic flight instructor," which involves no $90 written test and no $350 FAA flight test. The "test" is given by someone who is already a BFI, and has also been doing it more than 6 months and also has a 8-hour seminar. As I get older, the flight reviews, medicals, six approaches, 3 landings at night in a multi-engine taildragger, etc. seem more and more of a hassle. As I glance at the glider PTS and notice dozens of references including thousands of pages of detail, it occurs to me that being able to explain the "mixing ratio" may be required by my examiner, but certainly falls into the category that I would consider "obscure." In essence it is intimidating, even though it will be my 11th FAA checkride. I researched heavily to find two aero clubs in California with a very low "hassle factor" and minimum expense. But flying gliders and even very simple power planes is still more daunting in terms of sheer mass of requirements than that little Quicksilver Sprint MXII. And I have made great efforts to recruit friends to soaring, with little success mostly due to the "intimidation factor" of the ferocious checkride. I was truly heartened to see Dennis Wright's column where he echoed these same concerns (December "Soaring"). This is why I hope Sport Pilot goes through. I'd like to see something that makes piloting more available to the folks who want to have fun. |
Kirk Stant wrote:
Mark, your attitude scares me a bit. Sorry, but flying should be a bit intimidating - Nowhere in my post did I say hang gliding or ultralight flying, especially given the current rules, was safe. I simply don't have enough time doing either to evaluate that. My comments only referred to barriers to entry to the sport, i.e. "hassle factor." If you think there was any claim in that post that evaluated the safety or fatality rate in either sport, please reread the post. The whole ultralight scene totally scares me. Not that the majority of ultralight pilots don't fly relatively safely, but the attitude that "I can just jump into it and fly around, just like an ATV with wings" leads to some really scary flying - and some sad, stupid, unnecessary deaths, like we just had out at our glider field a few weeks ago. Can you tell me of any aviation accident with a pilot of any training level that wasn't "sad, stupid, and unecessary" ? As far as your particular affinity for ultralights goes, I hear ya. I must say I spent sevral days and a lot of kicking dust before flying it. I approached it just like any new aircraft: read the manual, read the common accidents, inspect the craft (castle nuts without cotter keys, is this wire supposed to be unloaded?, what about negative G's? Stall speed? Crosswinds? Turbulence? C.G.? This CG business was a real biggie). Then find an A&P and BFI with umpteen accident free hours (any idiot can have hours, how many are accident free?). There were several other things that made me SUPER scared (no shoulder harnesses or parachutes), and some mistakes (open cockpit means hats get blown about and double goggles are a good idea, good thing I wasn't the pilot). There was also one amazing confidence builder (ballistic parachute). If you haven't read about saves made by these things, I highly recommend it. I don't think I'll become an avid ultralight pilot, but it was an AMAZING eye opener and I'd highly recommend one flight with someone you've evaluated to your level of comfort. A wing that stalls at 18 mph is an amazing thing. Don't get me wrong, I'm not in favor of useless regulation - what I believe is needed (in all flying activities) is a lot of good training and knowledge about what can kill you. Thats what all the check rides are about - and without them anyone is just playing russian roulette with wings. I'm convinced the most interesting training absolutely does not improve safety, but only maintains the same level of safety while improving capability. Student pilots solo because they are safe, then train to fly further, higher, and with passengers, and in more interesting wind and weather (increasing capability). I believe the FAA should divide a LOT of PTS stuff out as endorsements. I believe all of these things should be endorsements, and NOT part of the PTS for any Sport Pilot license: 1. Radio use 2. Night flying 3. Instrument training 4. Airspace flying (D, C, B, A) 5. Cross-country flying 6. Flight at altitude over 12,500 7. Assembly/disassembly of aircraft (I mean beyond preflight) I think the FAA has, over time, divided out a lot of stuff as endorsements, and I think this is great. Launches, high-perf, complex, tailwheel, pressurization, IPC, solo in new cat/class, etc. I'm really excited about this trend. When I talk about "hassle factor" I'm really saying that it's a shame that a newbie pilot can't take a passenger up in a 2-33 without a checkride covering 1-7. Hassle factor? Name one really worthwhile activity that doesn't require lots of time, dedication, money, sweat, studying, etc. Sex. Think about it... That's what makes it worthwhile! Who do you think gets more outa glider flight, the guy who shows up at 9 am, rigs his ship, washes every bit of it (even a 1-26!), takes the lowest tow possible, flies regardless of the conditions (as long as it's safe) as long as he can, then puts his ship away and hangs around BS-ing with the locals watching the sun set - or the guy who only comes out to the field on a perfect day, reserves a plane from a commercial operator, takes a high tow, flies exactly 1.0 locally, lands, pays his bill, then leaves? I think the pilot should chose how much he wants to get out of flying, and if his flying simply doesn't involve 1-7, requiring it is a burden. I know one pilot who has a Waco and a Citabria. He was burdened by the 1-7, and the high-performance endorsement was off the mark (he needed it to fly a 210 hp with fixed prop). This guy flies day VFR in G and E airspace locally, and never sees 5000 feet. He just loves going up at every chance and making donuts in the sky. Who gets more out of gliding is not mine to determine. If someone likes a 1-26 because it can be left in the rain and not disassembled (and doesn't even know how) then jolly for him. If someone else wants to put lights on his glider, fly in clouds at 22,000 feet, and go 500km+, hey, that's cool too... When flight currency requirements start becoming hard to maintain, it's a good sign to stop pretending to be current in that activity and stick to something simpler. I couldn't agree more. I've largely given up trying to maintain my multi-engine currency, and my IFR is rusty enough that my personal minimums are way up (I won't do an ILS to mins). Trying to keep all those currencies has just been too much of a hassle... Think about it - a lot of times the instructor giving the checkride has less time and experience than the pilot getting the check - so teach him a thing or two! Good idea, I hope so. Bah Humbug (It's that season again - havn't flown in a couple of weeks) Merry Chrismas! I think for Christmas I might be getting a tiny baby girl. What's in your stocking? :-P Kirk 66 Mark 35 (but I always tell the ladies I'm 21) "rec.aviation.soaring - BS free since Dec 11, 2003 at 10:55 PST" |
Hi Mark,
I realized after hitting the "Post Message" button that my previous post came across as a bit (understatement!) arrogant and condescending. Sorry, it wasn't meant to be, I was reacting to the ultralight accident I mentioned, which has really colored my opinion about the whole "Flying is too complicated and hard, let's make it easier" trend. From your response it's obvious we actually think alike in many ways when it comes to flying - except for the Sports Pilot thing. If 14 year olds can solo gliders and be licenced by 16, having mastered all the technicalities and "hassles", then it really isn't that hard - it just takes determination and time (and money, of course - preferably someone else's!). Making it "easier" by crippling the performance of the planes and limiting the pilots freedom sounds like a bad and dangerous deal to me - and everything I have seen in the ultralight world confirms this - there is so much blatant disrespect for the limits going on, only the fact that when they kill themselves it is usually out in the middle of nowhere keeps the Feds from jumping in. The sad thing is that I love to fly real (meaning certificated) planes in the same performance range as the ultralights (J-3s and Champs comes to mind); and I have, but no-one makes any new ones because they can't compete with ultralights, so we are stuck with 50-year old designs or expensive antiques or homebuilts - and there goes the availability and affordability! I guess I just don't subscribe to the belief that "flying is for everybody" - heck, there are a lot of people out there who shouldn't even be driving a car! Of course, I guess that whatever happens, Darwin and gravity will sort it all out in the long run. It usually does. I just don't want to be in the same piece of sky when it happens. Cheers Kirk 66 Snobby Elitist Glasshole and PEZ addict |
(sorta OT) Free Ham Radio Course | RST Engineering | Home Built | 51 | January 24th 05 08:05 PM |
(sorta OT) Free Ham Radio Course | RST Engineering | Piloting | 43 | January 24th 05 08:05 PM |
Portable XM Radio receiver in the cockpit? | Peter R. | Piloting | 13 | September 4th 04 03:46 AM |
1944 Aerial War Comes to Life in Radio Play | Otis Willie | Military Aviation | 0 | March 25th 04 10:57 PM |
Ham Radio In The Airplane | Cy Galley | Owning | 23 | July 8th 03 03:30 AM |
