I'm installing a class C transponder in my LS-4, and I'd like to hear
from anyone who's done a similar installation with regard to a few questions about antenna location. Since the fusilage is not carbon fiber I intend to locate the antenna internally, and the easiest placement seems to be way forward in the nose 10 inches or so beyond the rudder pedals. There's room to attach the antenna and its reflector plate against an internal panel located on the roof of the nose with the coax cable led beneath the floorboards back to the transponder mounted on the instrument panel. The antenna would point downward from the roof of the nose. It looks like a clean, easy installation. Questions: 1) During transmit, the antenna puts out about 175 watts of RF. Is it going to toast my tootsies, or worse still, give me a bad case of toenail cancer, or is the frequency such that my feet have nothing to worry about? 2) There's some metal tubing structure attached to the floorboard beneath the antenna, probably annodized aluminum, that supports the rudder pedals and the heel-actuated wheel brake. Will that interfere with the antenna output? I'd be grateful for advice. I know from zilch about radios. |
I don't know zilch about radios either but did install a Becker transponder
and mode C box in my LS-8 last year. I did not place the antenna internally for the multiple reasons that you listed as potential problems below. I placed the antenna just aft of the gear doors and slightly off to the side. It is a fin-type antenna and I have had no problems with it going into the trailer or being in the way. I also had a thin layer of aluminum placed inside the fuselage as a ground plane as well as connecting that to the metal in the rest of the fuselage which I understand is utilized as the ground plane for the radio antenna. A separate independent battery runs it. It has worked well although I have not asked the controllers if they can see me yet. Casey Lenox KC Phoenix |
Others have also experienced good results with an internal
mount using the L2 antenna. Its flexable, can be bonded in place and requires no ground plane. See links below. http://www.advancedaircraft.com/index.htm http://www.gliderforum.com/thread-vi...d=131&posts=18 At 04:12 25 February 2004, Matt Herron wrote: I'm installing a class C transponder in my LS-4, and I'd like to hear from anyone who's done a similar installation with regard to a few questions about antenna location. Since the fusilage is not carbon fiber I intend to locate the antenna internally, and the easiest placement seems to be way forward in the nose 10 inches or so beyond the rudder pedals. There's room to attach the antenna and its reflector plate against an internal panel located on the roof of the nose with the coax cable led beneath the floorboards back to the transponder mounted on the instrument panel. The antenna would point downward from the roof of the nose. It looks like a clean, easy installation. Questions: 1) During transmit, the antenna puts out about 175 watts of RF. Is it going to toast my tootsies, or worse still, give me a bad case of toenail cancer, or is the frequency such that my feet have nothing to worry about? 2) There's some metal tubing structure attached to the floorboard beneath the antenna, probably annodized aluminum, that supports the rudder pedals and the heel-actuated wheel brake. Will that interfere with the antenna output? I'd be grateful for advice. I know from zilch about radios. |
I think there is some risk from radiation from these antenna's..most
avionics people I have talked with would not suggest mounting the antenna near any occupants.... for more information on antenna's and antenna installations there is a link to Comant form my page http://wingsandwheels.com/encoders.htm tim "Matt Herron" wrote in message om... I'm installing a class C transponder in my LS-4, and I'd like to hear from anyone who's done a similar installation with regard to a few questions about antenna location. Since the fusilage is not carbon fiber I intend to locate the antenna internally, and the easiest placement seems to be way forward in the nose 10 inches or so beyond the rudder pedals. There's room to attach the antenna and its reflector plate against an internal panel located on the roof of the nose with the coax cable led beneath the floorboards back to the transponder mounted on the instrument panel. The antenna would point downward from the roof of the nose. It looks like a clean, easy installation. Questions: 1) During transmit, the antenna puts out about 175 watts of RF. Is it going to toast my tootsies, or worse still, give me a bad case of toenail cancer, or is the frequency such that my feet have nothing to worry about? 2) There's some metal tubing structure attached to the floorboard beneath the antenna, probably annodized aluminum, that supports the rudder pedals and the heel-actuated wheel brake. Will that interfere with the antenna output? I'd be grateful for advice. I know from zilch about radios. |
VHF & Transponder antenna | Steve | Home Built | 1 | December 6th 04 04:29 PM |
Spare Transponder Antenna? | Jim Weir | Owning | 5 | May 25th 04 03:34 PM |
Oil on transponder antenna | Bob | Owning | 12 | May 9th 04 08:59 PM |
Transponder Antenna Location | Ken Kochanski | Soaring | 9 | January 9th 04 10:16 PM |
Wanted: Transponder antenna | Grandpa B. | Home Built | 22 | November 28th 03 08:03 AM |
