Michael, Kilo Charlie and others, thanks for the info.
It looks like the air mattress is the best solution for me. Kilo Charlie's tank and bilge pump is elegant but it requires a pick-up truck. Does anybody have a specific recommendation for a air mattress and any modifications that it will need? Bill Daniels "Michael Stringfellow" wrote in message news:wqVjc.10615$6L3.3055@fed1read05... This is a common problem for us here in Arizona, with several fields we fly at being dry. Looking at our cross-country pilots, who fly ballasted most of the time, the water storage/transport methods fall into the following three categories 1) Tanks of various shapes and sizes (rectangular and cylindrical), usually mounted in the vehicle or truck bed and with capacities in the 50 to 100 gallon range. 2) Rigid plastic containers. The blue 7-gallon ones (available from Mal-Wart) are a good compromise between capacity and ease of lifting. 3) Inflatable plastic containers (air beds), usually roof-mounted. We drive our vehicles carrying the water up to the glider. The most common filling method is gravity, with 12V electric pumps the second most common. Most of use a vertical open-ended pressure-relief tube to avoid over-pressure. Several pilots evacuate their bags with vacuum pumps prior to filling them. Hope this helps Mike ASW 20 WA "Bill Daniels" wrote in message news:G1Vjc.39485$cF6.1713298@attbi_s04... I Googled r.a.s and found posts about water beds, truck inner tubes and collapsible plastic cubes from Wal-Mart. The plastic cubes will transport 50 gallons and fit inside my Jeep Grand Cherokee but nothing else will fit and I don't want to unload the Jeep just for this chore. Full 10 gallon water containers weigh more than 90 pounds and I don't like lifting that much to pour it into the wing. I don't like water beds and inner tubes either. So, bright r.a.s people, how do you neatly and easily transport ballast water to the glider if the gliderport doesn't have a tanker or water hoses on the ramp? Once you get it there, how do you get it into the glider? Bill Daniels |
Induction System Water Problem | Mike Spera | Owning | 1 | January 30th 05 05:29 AM |
Bad publicity | David Starer | Soaring | 18 | March 8th 04 03:57 PM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
Water Cooled Jet Engines: a possibillity then and now? | The Enlightenment | Military Aviation | 3 | December 18th 03 09:41 AM |
I wish I'd never got into this... | Kevin Neave | Soaring | 32 | September 19th 03 12:18 PM |
