ELT Antenna
Old November 1st 04, 05:43 AM
Flyboy Chris
Just a note for all to keep in mind. Beginning in Jan 2009, the
satellites will no longer monitor 121.5/243.0 MHz for distress beacons.
Check out the COSPAS-SARSAT home page
(http://www.cospas-sarsat.org/MainPages/indexEnglish.htm), the FAA Home
Page (http://www.faa.gov/), or NOAA's SARSAT Page
(http://www.sarsat.noaa.gov/)
....zoom
Gary wrote:
Thanks for the reply. The issue really is the fact that carbon fiber
(lower
part of the tail) is not as good a ground plane as the metal of a
Cessna.
Should I be using the 'Z' type com antenna that is for building into
vertical stabalizer? Seems that type doesn't have the same
requirement for
a ground plane.
Gary
"UltraJohn" wrote in message
hlink.net...
A lot of the C-150's I've flown just had the ELT with attached whip
antenna
mounted to the side of the baggage area. Nothing fancy!
Usually it will be a satelite that will pick up the signal and get
earth
bound rescuers to the general area anyway so your not too concerned
about
line of sight.
John
Gary wrote:
Hello;
I am in the finishing stages of building a LIVP and realize that
I have
forgotten to allow for the elt. What antenna that would be
suitable to place in the tail area (where the top section is
fiberglass). Getting a ground plane will be difficult. Is there
an
alternative way to duplicate the effect of a ground plane? Is
there any
issue with proximity to com antennas? I have a wire whip 2nd
antenna that is in that section as well.
Thanks,
Gary Rodgers
Retractable Comm Antenna Ron Wanttaja Home Built 11 September 6th 04 06:59 PM
Another antenna question David Wilson Home Built 7 August 12th 04 10:04 PM
Antenna ground plane and coax grounding G. Fred McCutchen Home Built 2 August 8th 04 12:27 PM
ELT antenna -- Pitts Al MacDonald Home Built 0 July 15th 04 03:27 PM
comm's RX antenna acepilot Home Built 5 March 3rd 04 05:34 PM
