In article , Robert Ehrlich wrote:
d b wrote: I'm sure somebody may correct me, but as I recall, the TE probe produces a signal equal and opposite of the pitot (total pressure). Not exactly, total pressure is static + dynamic, TE is static - dynamic. Let's put it this way. The indicator reads the difference in pressure between the hole called P and the hole called S. When I hook the hole called P to a pitot tube and the hole called S to a perfect static source, I get a number, let's say 70. Now I hook a TE probe to the hole called S and the perfect static source to the hole called P. The indicator again reads 70. Obviously, the TE probe is the exact opposite of the pitot tube. It is agreed that the pitot is the total energy static + dynamic The obvious conclusion is that the TE probe is - (static + dynamic) It is NOT static - dynamic, it IS -(static+dynamic) Kinda sucks, doesn't it? |
d b wrote:
In article , Robert Ehrlich wrote: d b wrote: I'm sure somebody may correct me, but as I recall, the TE probe produces a signal equal and opposite of the pitot (total pressure). Not exactly, total pressure is static + dynamic, TE is static - dynamic. Let's put it this way. The indicator reads the difference in pressure between the hole called P and the hole called S. When I hook the hole called P to a pitot tube and the hole called S to a perfect static source, I get a number, let's say 70. Now I hook a TE probe to the hole called S and the perfect static source to the hole called P. The indicator again reads 70. Obviously, the TE probe is the exact opposite of the pitot tube. It is agreed that the pitot is the total energy static + dynamic The obvious conclusion is that the TE probe is - (static + dynamic) It is NOT static - dynamic, it IS -(static+dynamic) Kinda sucks, doesn't it? Yes it IS (static - dynamic). Go study your fluid dynamics again Cheers, John G. |
Perhaps it isn't obvious. The airspeed indicator is a DELTA pressure guage.
It is not an absolute pressure guage. If the indicator reads the same delta pressure, the two devices have to be producing the same delta pressure. One sucking, the other blowing. In article , "John Giddy" wrote: d b wrote: In article , Robert Ehrlich wrote: d b wrote: I'm sure somebody may correct me, but as I recall, the TE probe produces a signal equal and opposite of the pitot (total pressure). Not exactly, total pressure is static + dynamic, TE is static - dynamic. Let's put it this way. The indicator reads the difference in pressure between the hole called P and the hole called S. When I hook the hole called P to a pitot tube and the hole called S to a perfect static source, I get a number, let's say 70. Now I hook a TE probe to the hole called S and the perfect static source to the hole called P. The indicator again reads 70. Obviously, the TE probe is the exact opposite of the pitot tube. It is agreed that the pitot is the total energy static + dynamic The obvious conclusion is that the TE probe is - (static + dynamic) It is NOT static - dynamic, it IS -(static+dynamic) Kinda sucks, doesn't it? Yes it IS (static - dynamic). Go study your fluid dynamics again Cheers, John G. |
d b wrote:
Perhaps it isn't obvious. The airspeed indicator is a DELTA pressure guage. It is not an absolute pressure guage. If the indicator reads the same delta pressure, the two devices have to be producing the same delta pressure. One sucking, the other blowing. Or, if you have a good static system, one that neither blows nor sucks, but just sits there! -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
d b wrote:
In article , Robert Ehrlich wrote: d b wrote: I'm sure somebody may correct me, but as I recall, the TE probe produces a signal equal and opposite of the pitot (total pressure). Not exactly, total pressure is static + dynamic, TE is static - dynamic. Let's put it this way. The indicator reads the difference in pressure between the hole called P and the hole called S. When I hook the hole called P to a pitot tube and the hole called S to a perfect static source, I get a number, let's say 70. Now I hook a TE probe to the hole called S and the perfect static to the hole called P. The indicator again reads 70. Obviously, the TE probe is the exact opposite of the pitot tube. It is agreed that the pitot is the total energy static + dynamic The obvious conclusion is that the TE probe is - (static + dynamic) It is NOT static - dynamic, it IS -(static+dynamic) Kinda sucks, doesn't it? No, the reading of your indicator is P - S, converted into whatever speed unit you like. If P is connected to a pitot tube and S to a perfect static source, P - S is total - static = (static + dynamic) - dynamic) = dynamic). When P is connected to a perfect static source and S to a TE probe, P -S = static - (static - dynamic) = dynamic again, so the reading are the same. |
... P - S is total - static = (static + dynamic) - dynamic) = dynamic). ... correcting myself, should read: .... P - S is total - static = (static + dynamic) - static = dynamic. |
(PIREP, long) Cherokee 180 from Bay Area to Bishop, CA | Dave Jacobowitz | Piloting | 15 | June 24th 04 12:11 AM |
SWRFI Pirep.. (long) | Dave S | Piloting | 19 | May 21st 04 03:02 PM |
Showstoppers (long, but interesting questions raised) | Anonymous Spamless | Military Aviation | 0 | April 21st 04 05:09 AM |
making the transition from renter to owner part 1 (long) | Journeyman | Piloting | 0 | April 13th 04 02:40 PM |
Helicopter gun at LONG range | Tony Williams | Naval Aviation | 3 | August 20th 03 02:14 AM |
