Why are TE probes so long?
Old May 5th 04, 10:51 AM
John Giddy
d b wrote:
In article , Robert Ehrlich
d b wrote:
I'm sure somebody may correct me, but as I recall, the TE probe
produces a signal equal and opposite of the pitot (total
pressure).
Not exactly, total pressure is static + dynamic, TE is static -
dynamic.
Let's put it this way. The indicator reads the difference in
pressure
between
the hole called P and the hole called S. When I hook the hole called
P to a
pitot tube and the hole called S to a perfect static source, I get a
number,
let's say 70.
Now I hook a TE probe to the hole called S and the perfect static
source to
the hole called P. The indicator again reads 70. Obviously, the TE
probe is
the exact opposite of the pitot tube.
It is agreed that the pitot is the total energy static + dynamic
The obvious conclusion is that the TE probe is - (static +
dynamic)
It is NOT static - dynamic, it IS -(static+dynamic)
Kinda sucks, doesn't it?
Yes it IS (static - dynamic). Go study your fluid dynamics again
Cheers, John G.
Old May 5th 04, 12:31 PM
d b
Perhaps it isn't obvious. The airspeed indicator is a DELTA pressure guage.
It is not an absolute pressure guage. If the indicator reads the same delta
pressure, the two devices have to be producing the same delta pressure.
One sucking, the other blowing.
In article , "John Giddy"
pressure).
dynamic.
pressure
between
P to a
number,
let's say 70.
source to
probe is
dynamic)
Cheers, John G.
Old May 6th 04, 04:51 AM
Eric Greenwell
Or, if you have a good static system, one that neither blows nor sucks,
but just sits there!
Eric Greenwell
Washington State
USA
(PIREP, long) Cherokee 180 from Bay Area to Bishop, CA Dave Jacobowitz Piloting 15 June 24th 04 12:11 AM
SWRFI Pirep.. (long) Dave S Piloting 19 May 21st 04 03:02 PM
Showstoppers (long, but interesting questions raised) Anonymous Spamless Military Aviation 0 April 21st 04 05:09 AM
making the transition from renter to owner part 1 (long) Journeyman Piloting 0 April 13th 04 02:40 PM
Helicopter gun at LONG range Tony Williams Naval Aviation 3 August 20th 03 02:14 AM
