Mike, open and reseat pressures differ. A typical relief cartridge,
the Sun RDDA (www.sunhydraulics.com) says that reseat is 90% of set pressure. They don't say, but I suspect this is a Bernoulli force thing. Also, there is "override", the increase in pressure with increase in flow. I've not seen a response such as you describe on a direct-operated relief (spring/ball). I have seen gauges and transducers show one when there was air in the sense lines. Air other places could cause that, as well. Specifically, air in the oil stream would cause changes in flow through the relief valve in the setting-reseat region. On Tue, 2 Nov 2004 20:18:10 -0800, "Ron" no one @home.com wrote: On my O320 the pressure is on the side away from the ball, trying to open the bypass valve. The ball stays seated until pressure builds to the level of the bypass setting, then the bypass is forced open, allowing the excess pressure (oil) to be relieved back to the sump. "MikeremlaP" wrote in message ... Okay, here's the deal. Lycoming O-320 in a Glasair. On full power, whether oil is hot or cold, oil pressure will be higher than the regulator is set for. (Shoots to top of yellow arc - 90 psi. I think all Lyc's do that.) Upon power reduction, say turning downwind, you can "see" the ball jump off the seat when the oil pressure gage goes "sproing" and the pressure suddenly drops to the regulated 60 psi in a classic 2nd order damped sinusoidal response. It will stay at regulated pressure until the ball seats itself again, say on final approach with the engine at idle where the pump isn't making as much pressure. Then the process starts over again, on the next touch 'n' go. I'd like to have regulated oil pressure all the time. I'm theorizing that there's some kind of venturi effect, where the ball is actually sucked down harder on the seat when lots of oil is flowing past it on the engine side. Seems counter-intuitive, I know, but what else could be holding the ball down? Anyone got a simple fix I can try? Larger ball bearing? Smaller ball bearing? Cutting groves in the seat to help ball break free? Different angle on the face of the seat? |
Attn: Hydraulic experts - oil pressure relief fix? | MikeremlaP | Home Built | 0 | November 2nd 04 05:49 PM |
Pressure Differential in heat Exchangers | Bruce A. Frank | Home Built | 4 | July 3rd 03 05:18 AM |
