Peter,
Thanks. -- Mike Kanze "Never interrupt your enemy when he is making a mistake." - Napoleon Bonaparte "Peter Twydell" wrote in message ... In message , Mike Kanze writes José, How is the bridle attached to the Jug? (The second photo is too grainy for me to determine.) Roger A Freeman's "Thunderbolt, A documentary history of the Republic P-47",Macdonald and Jane's, London, 978, ISBN 0345111669, has a photo on page 83 of a P-47 on a catapult. The caption says it is Right Dee-Icer, a P-47D-11-RE of the 78th FG, and is aboard the USS Manilla Bay. The tail number starts with 27, and the next three digits could be 531. They are obscured by the starboard wing. It carries a centreline tank with shark's teeth markings on it. White nose, wing and tail band. "29" in white (probably) on the port wheel disc The cables can clearly be seen to be attached to the main gear legs just above the torque links. There seems to be some kind of hold-down behind the tailwheel. HTH -- Peter Ying tong iddle-i po! |
Attn: Hydraulic experts - oil pressure relief fix? | MikeremlaP | Home Built | 7 | November 6th 04 08:34 PM |
Attn: Hydraulic experts - oil pressure relief fix? | MikeremlaP | Home Built | 0 | November 2nd 04 05:49 PM |
aero-domains for homebuilt experts | secura | Home Built | 0 | June 26th 04 07:11 AM |
JASPO Experts On Civil Aircraft Survivability | sid | Military Aviation | 2 | February 13th 04 07:41 AM |
Aircraft Id needed from newsgp experts! | RGP | Military Aviation | 1 | January 1st 04 07:15 PM |
