I found them at a supplier of hardware for truck and trailer
fabricators, they have them in plated and stainless. Get the ones which allow a lock to be inserted and use small carabiner clips instead and they will never open unexpectedly on you. To avoid the curved surface issue I epoxied a wedge under each half so the latch runs straight, then filleted in with more epoxy. I also installed a 'fork' arrangement, a small plate under the catch plate shaped like a wide fork to capture the opposing clamp, to retain alignment of the two dolly halves under load. I think this will extend the life of the hinges as well, I replaced them with thicker truck hardware stainless hinges. Get the heaviest clamps you can fit on, don't be tempted by the cute little ones! Bigger is best! Slip a piece of 'snug' tubing over the threaded adjusting portion to keep it from rotating back loose when unlatched. I'll email a small photo of the trial fitting. Bob |
Tail Skid Help / Advice | Ray Lovinggood | Soaring | 3 | January 2nd 04 08:16 PM |
AH64 tail rotor | CivetOne | Rotorcraft | 3 | October 23rd 03 07:18 PM |
Tail Dolly For Sale | Albert Gold | Soaring | 0 | October 15th 03 03:01 AM |
Oshkosh Get together Roster - Sign in, please! | Bruce E. Butts | Piloting | 1 | July 26th 03 11:34 AM |
The prone postion for tail gunners versus turrets. | The Enlightenment | Military Aviation | 8 | July 22nd 03 11:01 PM |
