Why the T-Tail?
Old October 26th 04, 11:38 AM
Stefan
Pro T-tail: It's in the clean air.
Contra T-tail: Huge torque forces.
The torque forces are more easily mastered when the planes are small.
There are biz jets and turboprops with T-tails. On the other hand, all
serious acro planes, gliders included, have "conventional" tails.
Stefan
Old October 27th 04, 01:35 PM
Gerhard Wesp
I know what force is and what torque is, but what's ``torque force''?
I see no significant difference in the pitch torque generated by a T
tail and a conventional tail (apart from a minimally longer arm for a T
tail on a given typical glider design).
Am I missing something?
-Gerhard
Gerhard Wesp o o Tel.: +41 (0) 43 5347636
Bachtobelstrasse 56 | http://www.cosy.sbg.ac.at/~gwesp/
CH-8045 Zuerich \_/ See homepage for email address!
Old October 27th 04, 01:59 PM
Jim Vincent
The torque is around the rolling axis, not the pitch axis.
With a conventional tail, the rolling torque is based on the distance from the
fuselage center line to the CG of the elevator surface. In a T-tail, the
distance is based on the whole length of the vertical fin, so the moment arm is
greater. Hence, greater torque force.
Jim Vincent
N483SZ
illspam
Old October 27th 04, 04:03 PM
F.L. Whiteley
"Jim Vincent" wrote in message
arm is
Jim Vincent
Ever watch a Zuni tail during take off? I gather it's also interesting to
watch in flight, but Zuni drivers don't really like using mirrors;^)
Frank Whiteley
Old October 27th 04, 02:04 PM
Stefan
It's me being sloppy in the usage of a language which isn't my first one.
Stefan
Old October 27th 04, 02:18 PM
Jim Vincent
Stefan
Stefan, if you use that excuse, that leaves those of us for whom English is
the first language with no excuses for when we're sloppy;-)
Jim Vincent
N483SZ
illspam
Old October 27th 04, 04:30 PM
Jim Vincent
Actually, it is me being sloppy.
Torque is really the moment arm times the force (R X F). The force is the same
since the elevator is merely translated from one position to another. The
moment arm increases from the base of the fin to the top of the fin. So it is
the torque that increased, not the "force" per se.
Then again, with a T-tail, the elevator is no longer essentially in rotation,
but also in translation, so there that to consider too...
Jim Vincent
N483SZ
illspam
Old October 28th 04, 12:32 AM
John Giddy
On 27 Oct 2004 15:30:43 GMT, Jim Vincent wrote:
snip
Jim Vincent
N483SZ
illspam
Jim,
Why does the elevator have more translation on a T-Tail than on a
conventional one please ? (I presume you are referring to translation
in a direction normal to the tailplane surface)
Bemused John G.
Old October 28th 04, 03:44 AM
Jim Vincent
Jim,
Bemused John G.
John,
If the stab is mounted at the fuselage, if there is roll, the stab only
experiences a rotation around the center of the stab.
If the stab is T, then not only is it rotating, it is also moving in a circle
with a diameter of the rudder fin. Does that make sense?
Also, with a T, if you go full rudder in one direction then another, the fin
adds the inertia of the stab mounted at the top of the rudder...a torsion from
yaw too!
Jim Vincent
N483SZ
illspam
Old October 28th 04, 04:41 AM
John Giddy
On 28 Oct 2004 02:44:06 GMT, Jim Vincent wrote:
Jim,
Bemused John G.
John,
yaw too!
Jim Vincent
N483SZ
illspam
OK Jim,
I agree. I was thinking of normal elevator operation, and movement in
the pitch direction, which is the same for both arrangements.
Cheers, John G.
Tail Skid Help / Advice Ray Lovinggood Soaring 3 January 2nd 04 08:16 PM
AH64 tail rotor CivetOne Rotorcraft 3 October 23rd 03 07:18 PM
Oshkosh Get together Roster - Sign in, please! Bruce E. Butts Owning 1 July 26th 03 11:34 AM
Oshkosh Get together Roster - Sign in, please! Bruce E. Butts Piloting 1 July 26th 03 11:34 AM
The prone postion for tail gunners versus turrets. The Enlightenment Military Aviation 8 July 22nd 03 11:01 PM
