![]() "Blueskies" wrote in message news ![]() "Jim Burns" wrote in message ... I've always had a well founded and severe fear of using any type of ice melt product around our hanger entrance. As a farmer, I know what ammonium nitrate, ammonium sulfate, potassium chloride etc. are and what they can do to your equipment. Recently our FBO started selling an palletized ice melt made of ammonium sodium acetate, the dry prilled form of the liquid product that they spray on the runways as a ice preventative. Does anybody know the corrosive properties of ammonium sodium acetate? Thanks Jim We started getting quite a few of our pups back from European operators with the cad plated parts very corroded. Turns out the Europeans were using some sort of new deicer stuff on their runways and all. Unfortunately I do not know what it was exactly, but you can do some testing on your own parts. Get some old screw hardware from your local mechanic and see what happens... That pups should be pumps, as in hydraulic. http://www.parker.com/ag/pdf/abexbrochure.pdf in case you are interested... |
![]() "Blueskies" wrote in message ... We started getting quite a few of our pups back from European operators with the cad plated parts very corroded. Turns out the Europeans were using some sort of new deicer stuff on their runways and all. Unfortunately I do not know what it was exactly, but you can do some testing on your own parts. Get some old screw hardware from your local mechanic and see what happens... That pups should be pumps, as in hydraulic. http://www.parker.com/ag/pdf/abexbrochure.pdf in case you are interested... Cadmium plating is routinely stripped from the base metal using an amonium nitrate solution, hence the corrosion. |
![]() "Franklin Newton" wrote in message .net... "Blueskies" wrote in message ... We started getting quite a few of our pups back from European operators with the cad plated parts very corroded. Turns out the Europeans were using some sort of new deicer stuff on their runways and all. Unfortunately I do not know what it was exactly, but you can do some testing on your own parts. Get some old screw hardware from your local mechanic and see what happens... That pups should be pumps, as in hydraulic. http://www.parker.com/ag/pdf/abexbrochure.pdf in case you are interested... Cadmium plating is routinely stripped from the base metal using an amonium nitrate solution, hence the corrosion. That may be the case, and maybe ammonium nitrate was the 'new' material that was being used over there, but it the problem was sudden and they are no longer using whatever-it-was because the problem has gone away. Almost all of the steel components on the pumps are cad plated, as well as many of the landing gear parts. There was quite an uproar there for a while... |
ice melt | Jim Burns | Owning | 11 | February 23rd 05 10:21 PM |
WeserFlug P.1003 Compared to V-22 Osprey | robert arndt | Military Aviation | 29 | December 2nd 03 06:23 PM |
