How long before /G required for IFR?
Old February 27th 05, 01:51 PM
Dan Thompson wrote:
Tim, some of the other guys are playing around with you a little bit, but
I'll spell it out for you since I started it.
Thanks for "helping" me. Have you ever heard of Class I and Class II
navigation? Those are ICAO terms that define what constitutes acceptable IFR
navigation in three different defined areas: domestic, oceanic, and remote land
mass. The United States is a signatory to that convention. The VOR system is
thus considered the primary means of IFR navigation. With limited exceptions,
IFR-certified GPS is not approved as primary means in a non-radar environment in
domestic airspace. That is changing, of course. But, it does not include VFR
GPS units, which do not qualify for IFR navigation.
That reg says what you have to have onboard, but does not say what you will
or must use for navigation. IFR course tracking is a performance standard.
You must stay on the assigned course. How you do that is not specified or
regulated. What you use to fly that course is not specified or regulated.
Only that you fly that course, somehow.
So, you may use dead reckoning if you want to, radar vectors, celestial nav
(right!), or even (the crowd is on the edge of their seats in anticpation) a
tuna sandwich. The tuna sandwich must not, however, be placarded "VFR
only."
So, it is perfectly acceptable to look at your handheld GPS, see that it
says 237 degrees and 16 minutes to FUBAR, dead reckon by flying a 237
heading, and monitor your progress by reference to the handheld GPS.
wrote in message ...
Michael wrote:
But, how much longer will it be before /G is a de facto requirement?
IMO, more than 5 years but less than 15.
Already when I fly IFR (filed /U) controllers give me instructions
("proceed direct foobar") that require GPS
Well, they don't really. I bet you can do that with the M1 LORAN. Or
you could if it didn't come with a placard limiting it to VFR use only.
A handheld GPS will not come with such a placard, and there's no rule
that says you can't use it for enroute IFR (anyone who says otherwise
is welcome to quote chapter and verse from the approriate regulation -
NOT an advisory circular or AIM).
Try 91.205 (d) (2) for starters:
d) Instrument flight rules. For IFR flight, the following instruments and
equipment are required:
(2) Two-way radio communications system and navigational equipment
appropriate to the ground facilities to be used.
Think non-radar operations, where the controller isn't going to play
"Frick
and Frack" direct-to games with you. Failure to comply with 91.205 can
rapidly lead to 91.3, and the FAA attorneys win every time.
Old February 27th 05, 05:37 PM
Dan Thompson
"Those are ICAO terms that define what constitutes acceptable IFR
land
mass."
That's nice, but where does it say VOR is the "only" ONLY o.n.l.y acceptable
means of IFR navigation? All this says is that VOR is an acceptable means,
world wide. A sort of lowest common denominator that may be used all over
the planet.
IFR
land
system is
exceptions,
environment in
VFR
will
standard.
or
regulated.
nav
anticpation) a
only."
only.
and
"Frick
Christmas Annual - long drivel Denny Owning 23 December 31st 04 08:52 PM
Does China have long range bombers? Mike Military Aviation 10 May 24th 04 02:16 AM
SWRFI Pirep.. (long) Dave S Piloting 19 May 21st 04 03:02 PM
making the transition from renter to owner part 1 (long) Journeyman Piloting 0 April 13th 04 02:40 PM
First flight with my wife! (long) Wily Wapiti Piloting 8 August 30th 03 05:57 PM
