1. Simplest solution is a dumb charger that doesn't know whether it is
attached to a battery or not... That will put out DC power, no matter what, which will provide the Piper solenoid with current to operate... Of course, a dumb charger will over charge to 15 or 16 volts and boil off the electrolyte over time... Now, the solution here is to reduce the primary voltage to the charger so that the charging voltage does not exceed 13.4 volts DC in trickle mode... This can be as simple as a light bulb socket from the hardware store wired to a duplex plug in SERIES, so that the 110 volt current goes through the bulb and then through the 110v cord to the charger... By selecting a small enough wattage bulb you will limit the voltage and current to the charger which will hold down the battery voltage to 13.4 v under trickle conditions... You can play with the bulb size at home using your car as the airplane battery until you get the correct wattage bulb.. 2. Next solution is to have a small battery attached to the output of the charger which will supply the load to activate the charger and also to operate the solenoid in the plane.. 3.. Best solution! Have your mechanic change the Positive lead from the Piper plug so that it goes around the solenoid and directly to the battery... This is how I have Fat Albert The Apache wired (and every airplane I have ever owned) for charging and jump starting... denny |
"Denny" writes:
1. Simplest solution is a dumb charger that doesn't know whether it is attached to a battery or not... That's where I was headed but, as you described, it wouldn't be good for long-term use and that's what I really want. I'd like to just plug it in when I put away the plane, just as I do for the engine heaters. That way I'd be able to run the cabin heater for awhile when I'm getting ready for the next flight without worrying so much about the battery not handling it. Stepping down the voltage is certainly an option. I'm not looking for a fast charge. 2. Next solution is to have a small battery attached to the output of the charger which will supply the load to activate the charger and also to operate the solenoid in the plane.. I finally stumbled on to that yesterday. I have a portable "jump start" battery (with a handy inverter attached). I realized that if I connect that to the power port and then plug its charger into it, I have basically what I want. It would also be handy for helping to run the heater after I pull the plane out of the hangar, especially on trips away from home (where I could charge it at a hotel or in a rental car). 3.. Best solution! Have your mechanic change the Positive lead from the Piper plug so that it goes around the solenoid and directly to the battery... This is how I have Fat Albert The Apache wired (and every airplane I have ever owned) for charging and jump starting... You had no problem with that?! Cool! I wanted this anyway because I'd like to make a 12VDC tug and the power port is sitting right there just begging to be used. (Having my tug not start recently makes this even more enticing.) Sidenote: I didn't realize the small airplane tug was invented right here at Purdue...in 2003 (well after I bought my PowerTow). http://news.uns.purdue.edu/UNS/html4...fi.towbar.html Otherwise, pilots have to muscle their planes into place with a manual towbar or have someone at the airport use a tractor- like towing vehicle, There must have been some reason to have the port "protected" by the relay. Are we sure that this is safe and not (more) likely to rankle any FSDO types? I sure don't see the harm in it other than producing a signficant reaction if a conductor is jammed into the port. I wouldn't mind replacing the solenoid with a manual switch inside the nose baggage compartment. Thanks! --kyler |
Kyler Laird writes:
{Switched power port} I'm trying to grok how this works. What comes to mind is a 3-ping connector: Hot, Ground, Control. Put +13v on the third pin by having it jumpered to Hot WITHIN the cable's plug and that will do it. You can then put a diode in series with the control lead so as to NOT close the relay if the polarity is backwards. (Doing so would result in what a former cow orker called "Big Sparky-Do's"... as the two 13.8 v sources would be in series with the only resistance being the wiring and contactor..) A diode in series with the main lead with a) need to be BIG... b) introduce unwanted voltage drop. But is this how they did it? Suspect not... 3.. Best solution! Have your mechanic change the Positive lead from the Piper plug so that it goes around the solenoid and directly to the battery... This is how I have Fat Albert The Apache wired (and every airplane I have ever owned) for charging and jump starting... You had no problem with that?! Cool! I wanted this anyway because I'd like to make a 12VDC tug and the power port is sitting right there just begging to be used. (Having my tug not start recently makes this even more enticing.) Err. reverse polarity protection? And a short at the external cables may start a fire inside.... -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
Kyler Laird writes:
3.. Best solution! Have your mechanic change the Positive lead from the Piper plug so that it goes around the solenoid and directly to the battery... This is how I have Fat Albert The Apache wired (and every airplane I have ever owned) for charging and jump starting... You had no problem with that?! Cool! I wanted this anyway because I'd like to make a 12VDC tug and the power port is sitting right there just begging to be used. (Having my tug not start recently makes this even more enticing.) I'm an EE, not an A&P, but your plan really scares me. The external power jack is unfused so you can jump-start from it. That's why the solenoid has that scheme to keep a "dead face" aka no power on the exposed pin. I don't suggest this lightly, knowing the BS and $$, but have you considered adding a 2nd jack, smaller in size? That COULD be fused at say 60A, and always live. That could accommodate both a charger, or your power-tug, with no risk to your aluminum friend...or you while in it. -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
David Lesher writes:
I don't suggest this lightly, knowing the BS and $$, but have you considered adding a 2nd jack, smaller in size? That COULD be fused at say 60A, and live. That could accommodate both a charger, or your power-tug, with no risk to your aluminum friend...or you while in it. Standing at the plane a few nights ago, I considered the same thing. I've been working on blending a small charger and some old batteries (from my electric lawn mower) to make a compatible charger. I decided that I should add some resistance just in case one of the batteries (plane or charger) gets really low. I don't want a sudden rush through it. Then I realized that if I'm going to do that I might as well just use small connectors and wire. And if I'm going to do that I don't really need to use the high-power port. However...using the existing power port is handy. The best thing about it is that it's externally accessible. I can put a charger on it without leaving the nose open. I leave expensive stuff (headsets) in the nose so even in my (shared) hangar it's worthwhile to keep it locked, but it's especially advantageous if I'm on the ramp somewhere leaving the cabin and engine and heaters on. Perhaps the answer is to bridge the relay contacts with a low-current toggle circuit breaker? That would allow me to easily control whether or not trickle charging or discharge can occur through the port but if I happen to leave it enabled and a short or reverse polarity condition occurs the circuit would be broken. See any problems with that? Thank you. --kyler |
Kyler Laird writes:
I don't suggest this lightly, knowing the BS and $$, but have you considered adding a 2nd jack, smaller in size? That COULD be fused at say 60A, and live. That could accommodate both a charger, or your power-tug, with no risk to your aluminum friend...or you while in it. Standing at the plane a few nights ago, I considered the same thing. I've been working on blending a small charger and some old batteries (from my electric lawn mower) to make a compatible charger. What you want is a trickle charger; it need furnish only say 100mA or so. (This assumes you religiously plug it in while hangared, of course. Same scheme as most firetrucks.) A common source is the residential alarm industry; they use a small PCB with a regulator and a wallwart transformer. {I'll give you one if you need it.....just to do it safely..} I decided that I should add some resistance just in case one of the ..... Good! However...using the existing power port is handy. My point was: "using AN external port is handy.." Perhaps the answer is to bridge the relay contacts with a low-current toggle circuit breaker? That would allow me to easily control whether or not trickle charging or discharge can occur through the port but if I happen to leave it enabled and a short or reverse polarity condition occurs the circuit would be broken. If you do that; the "ground power" contactor will close and stay closed; costing you your protection. Hmm, you'd need a SPDT switch I think but I'd want to draw it out. Not undoable, and perhaps cheaper than a 2nd hole in the skin, etc. -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
: I decided that I should add some resistance just in case one of the
: batteries (plane or charger) gets really low. I don't want a sudden : rush through it. Then I realized that if I'm going to do that I might : as well just use small connectors and wire. And if I'm going to do : that I don't really need to use the high-power port. I would think a circuit breaker would be a better idea than a resistor. If you go through the trouble of making a well-thought-out bypass for the interlocking mechanism, why limit yourself to a trickle charge? : Perhaps the answer is to bridge the relay contacts with a low-current : toggle circuit breaker? That would allow me to easily control whether : or not trickle charging or discharge can occur through the port but if : I happen to leave it enabled and a short or reverse polarity condition : occurs the circuit would be broken. I think that this could be done well, but I would try to add some interlocking to the bypass. Probably some diode logic to the coil of a relay. Then you could protect yourself from reverse polarity on the plug, and overcurrent protect the large solenoid bypass. Without schematics I can't say for sure the best way, but as I said before, I'd try to think of every possible failure mode. I'm sure that Piper did. Along the same lines, I've notice a significant difference in the later PA-28's from my '69 model. Mine has a 60A breaker in the ALT feed line and the later ones don't. All I can say is if mine ever tripped, it could put a big load dump transient on the bus. That could cook a lot of avionics in a hurry. Be careful, -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
What you need is a REGULATED lab power supply that has adjustable
voltage and current adjustments. I use a 0 to 33 volt at 0 to 30 amp power supply that has digital readouts for voltage and current that I bought surplus. Set the charge voltage and max charge current and plug it in. As the battery charges the supply will switch from current limit mode to voltage limit mode automatically. You cannot feed the power into the APU port for a long time (more than 10 minutes) or it will generally fry the APU port relay because most are not rated for continuous operation. Install a charging jack on an inspection panel and wire it direct to the battery with a FUSE at the battery that will support the expected charging current from your power supply. For 12v systems set the power supply to 14.00 to charge overnight or 13.45 for long term float charge. Double these voltages for a 24 volt system. These voltages need to be adjusted some what if the temperature is not close to 70F. This voltage verses temperature data can be found on the internet for the type of battery you are using. You do NOT want to use a low cost common UNREGULATED trickle charger or you will surely fry your expensive battery by over charging. Don't take the battery caps off unless you intend to charge at very high rates or the acid will cover everything near the battery. John On Thu, 17 Mar 2005 15:08:05 GMT, Kyler Laird wrote: David Lesher writes: I don't suggest this lightly, knowing the BS and $$, but have you considered adding a 2nd jack, smaller in size? That COULD be fused at say 60A, and live. That could accommodate both a charger, or your power-tug, with no risk to your aluminum friend...or you while in it. Standing at the plane a few nights ago, I considered the same thing. I've been working on blending a small charger and some old batteries (from my electric lawn mower) to make a compatible charger. I decided that I should add some resistance just in case one of the batteries (plane or charger) gets really low. I don't want a sudden rush through it. Then I realized that if I'm going to do that I might as well just use small connectors and wire. And if I'm going to do that I don't really need to use the high-power port. However...using the existing power port is handy. The best thing about it is that it's externally accessible. I can put a charger on it without leaving the nose open. I leave expensive stuff (headsets) in the nose so even in my (shared) hangar it's worthwhile to keep it locked, but it's especially advantageous if I'm on the ramp somewhere leaving the cabin and engine and heaters on. Perhaps the answer is to bridge the relay contacts with a low-current toggle circuit breaker? That would allow me to easily control whether or not trickle charging or discharge can occur through the port but if I happen to leave it enabled and a short or reverse polarity condition occurs the circuit would be broken. See any problems with that? Thank you. --kyler |
John_F wrote:
: For 12v systems set the power supply to 14.00 to charge overnight or : 13.45 for long term float charge. Double these voltages for a 24 volt : system. These voltages need to be adjusted some what if the : temperature is not close to 70F. This voltage verses temperature data : can be found on the internet for the type of battery you are using. You may want slightly higher voltages than that. From what I've read, and from working on a hybrid electric car with lead-acid batteries (granted, they were SLA, not FLA), you can alegedly float them at 13.8 indefinately without damage. As for an overnight, 14.0 probably won't give quite an equalization charge on the cells. It may bubble a little bit, but 14.5 will probably help rejuvenate the cells more than 14... again, *only* for an overnight charge... not indefinately. -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
'73 Piper Charger | Kobra | Instrument Flight Rules | 1 | March 27th 04 08:49 PM |
'73 Piper Charger | Kobra | Owning | 1 | March 27th 04 08:49 PM |
Piper Pathfinder Article | john smith | Piloting | 24 | March 14th 04 01:04 AM |
Battery Replacement and Cold Cranking Amps | O. Sami Saydjari | Owning | 27 | February 2nd 04 02:38 PM |
New Piper Aircraft Designations | EDR | Piloting | 8 | October 27th 03 01:18 PM |
