battery charger to get through Piper power port?
Old March 17th 05, 03:24 PM
David Lesher
Kyler Laird writes:
I don't suggest this lightly, knowing the BS and $$, but have you
considered adding a 2nd jack, smaller in size? That COULD be fused
at say 60A, and live. That could accommodate both a charger, or your
power-tug, with no risk to your aluminum friend...or you while in it.
Standing at the plane a few nights ago, I considered the same thing.
I've been working on blending a small charger and some old batteries
(from my electric lawn mower) to make a compatible charger.
What you want is a trickle charger; it need furnish only say 100mA
or so. (This assumes you religiously plug it in while hangared, of
course. Same scheme as most firetrucks.) A common source is the
residential alarm industry; they use a small PCB with a regulator
and a wallwart transformer. {I'll give you one if you need it.....just
to do it safely..}
I decided that I should add some resistance just in case one of the
Good!
However...using the existing power port is handy.
My point was: "using AN external port is handy.."
Perhaps the answer is to bridge the relay contacts with a low-current
toggle circuit breaker? That would allow me to easily control whether
or not trickle charging or discharge can occur through the port but if
I happen to leave it enabled and a short or reverse polarity condition
occurs the circuit would be broken.
If you do that; the "ground power" contactor will close and stay closed;
costing you your protection. Hmm, you'd need a SPDT switch I think but
I'd want to draw it out. Not undoable, and perhaps cheaper than a 2nd
hole in the skin, etc.
A host is a host from coast to
& no one will talk to a host that's close........[v].(301) 56-LINUX
Unless the host (that isn't close).........................pob 1433
is busy, hung or dead....................................20915-1433
'73 Piper Charger Kobra Instrument Flight Rules 1 March 27th 04 08:49 PM
'73 Piper Charger Kobra Owning 1 March 27th 04 08:49 PM
Piper Pathfinder Article john smith Piloting 24 March 14th 04 01:04 AM
Battery Replacement and Cold Cranking Amps O. Sami Saydjari Owning 27 February 2nd 04 02:38 PM
New Piper Aircraft Designations EDR Piloting 8 October 27th 03 01:18 PM
