Jim Carriere wrote:
This is one of those questions where there must be a simple answer. This is probably the forum to get the best explanation. Why aren't vacuum driven gyro instruments driven by pressure instead? Well, they are. They are driven by a pressure differential between the input and output. As for why we lower the output pressure rather than raising the input pressure...I'm guessing that a venturi in the airflow is easier/better/more efficient than trying to use some sort of ram air device to raise it. |
nafod40 wrote:
Jim Carriere wrote: This is one of those questions where there must be a simple answer. This is probably the forum to get the best explanation. Why aren't vacuum driven gyro instruments driven by pressure instead? Some systems ARE designed to work off of pressure. Depending on the system designer. John |
UltraJohn wrote:
nafod40 wrote: Jim Carriere wrote: This is one of those questions where there must be a simple answer. This is probably the forum to get the best explanation. Why aren't vacuum driven gyro instruments driven by pressure instead? Some systems ARE designed to work off of pressure. Depending on the system designer. John If the carbon vanes in a vacuum pump fail, any debris will be blown overboard. If the pump pressurizes the instruments, the debris will be blown into the instruments, ruining them. |
Colibri wrote:
If the carbon vanes in a vacuum pump fail, any debris will be blown overboard. If the pump pressurizes the instruments, the debris will be blown into the instruments, ruining them. This is a good point, although hopefully a filter would protect against this expensive possibility. |
designer. John If the carbon vanes in a vacuum pump fail, any debris will be blown overboard. If the pump pressurizes the instruments, the debris will be blown into the instruments, ruining them. The Piper PA 31 Navajos for one use a pressure system with a filter between the pumps and the instruments. John Dupre' |
Most airplanes that have de-icing boots use a pressure system. Even some
Bonanza even without the boots. "JDupre5762" wrote in message ... Some systems ARE designed to work off of pressure. Depending on the system designer. John If the carbon vanes in a vacuum pump fail, any debris will be blown overboard. If the pump pressurizes the instruments, the debris will be blown into the instruments, ruining them. The Piper PA 31 Navajos for one use a pressure system with a filter between the pumps and the instruments. John Dupre' |
UltraJohn wrote:
nafod40 wrote: Jim Carriere wrote: This is one of those questions where there must be a simple answer. This is probably the forum to get the best explanation. Why aren't vacuum driven gyro instruments driven by pressure instead? Some systems ARE designed to work off of pressure. Depending on the system designer. Hmm, I learn something new every day. I figured maybe there was some technical reason they had to use vacuum, since most of the instruments one can buy seem to be either electrical or vacuum. From your answer, I suppose there is no real reason, maybe most of the non electrical ones are vacuum because that is just the way things are. |
![]() Hmm, I learn something new every day. I figured maybe there was some technical reason they had to use vacuum, since most of the instruments one can buy seem to be either electrical or vacuum. From your answer, I suppose there is no real reason, maybe most of the non electrical ones are vacuum because that is just the way things are. Colibri's response is why most are driven off the vacuum side but it isn't a requirement. Like was mentioned the filter provides some protection. According to an article in the newest Private Pilot magazine on twins. The Beech Duchess Model 76 that they review is run off the pressure side of the pumps (page 52, February 2005). They also mention most Beechcrafts are done that way. John |
Wet vs Dry Vacuum Pump | Fastglasair | Home Built | 1 | December 15th 04 05:17 PM |
Wet Vacuum Pumps | DBlumel | Home Built | 4 | August 19th 04 08:27 AM |
Newbie Question - Vacuum vs Electric | Bill Denton | Aerobatics | 1 | April 15th 04 11:30 PM |
Gyro Copter for Sale on EBAY | EC155 Pilot | Home Built | 0 | November 1st 03 11:34 PM |
NACA duct ventrui | Chris W | Home Built | 7 | October 27th 03 04:11 PM |
