Vacuum Gyro Question
Old January 8th 05, 11:01 PM
UltraJohn
nafod40 wrote:
Jim Carriere wrote:
This is one of those questions where there must be a simple answer. This
is probably the forum to get the best explanation.
Why aren't vacuum driven gyro instruments driven by pressure instead?
Some systems ARE designed to work off of pressure. Depending on the system
designer.
John
Old January 8th 05, 11:16 PM
Colibri
designer.
John
If the carbon vanes in a vacuum pump fail, any debris will be blown
overboard. If the pump pressurizes the instruments, the debris will be
blown into the instruments, ruining them.
Old January 9th 05, 12:31 AM
Jim Carriere
This is a good point, although hopefully a filter would protect
against this expensive possibility.
Old January 10th 05, 12:44 AM
JDupre5762
designer.
John
The Piper PA 31 Navajos for one use a pressure system with a filter between the
pumps and the instruments.
John Dupre'
Old January 22nd 05, 03:04 AM
Cy Galley
Most airplanes that have de-icing boots use a pressure system. Even some
Bonanza even without the boots.
"JDupre5762" wrote in message
system
designer.
John
between the
John Dupre'
Old January 8th 05, 11:48 PM
Jim Carriere
designer.
Hmm, I learn something new every day.
I figured maybe there was some technical reason they had to use
vacuum, since most of the instruments one can buy seem to be either
electrical or vacuum. From your answer, I suppose there is no real
reason, maybe most of the non electrical ones are vacuum because that
is just the way things are.
Old January 9th 05, 01:01 AM
UltraJohn
Colibri's response is why most are driven off the vacuum side but it isn't a
requirement. Like was mentioned the filter provides some protection.
According to an article in the newest Private Pilot magazine on twins. The
Beech Duchess Model 76 that they review is run off the pressure side of the
pumps (page 52, February 2005). They also mention most Beechcrafts are done
that way.
John
Wet vs Dry Vacuum Pump Fastglasair Home Built 1 December 15th 04 05:17 PM
Wet Vacuum Pumps DBlumel Home Built 4 August 19th 04 08:27 AM
Newbie Question - Vacuum vs Electric Bill Denton Aerobatics 1 April 15th 04 11:30 PM
Gyro Copter for Sale on EBAY EC155 Pilot Home Built 0 November 1st 03 11:34 PM
NACA duct ventrui Chris W Home Built 7 October 27th 03 04:11 PM
