B2431 wrote:
From: (Floyd L. Davidson) Date: 1/9/2005 11:09 Central Standard Time Message-id: "Blueskies" wrote: "Henry Kolesnik" wrote in message y.com... No one has mentioned that cable mining is much safer and easier with laced cables and can be impossible with ty wrapped cables. -- 73 Hank WD5JFR What is cable mining? New cables are laid into cable racks on top of old cables, and the old ones that are no longer used are just cut off where they enter the cable rack and left in place. Eventually, of course, the cable rack fills up with old unused cable. When I used to work C-130s I would get called out to identify "extra" cannon plugs that didn't seem to attach to anything. Most commonly were the 2 behind the instrument panel that went to the old ADI and ADI amp. I wonder if they are still there. Probably. Why would you take them out unless you replaced the harness? Matt |
Best lubricant for Mechanical Tachometer Cable??? | RonLee | Home Built | 3 | January 4th 05 12:04 AM |
Can anyone help, PLEASE - searching for zip-cord (aka: mono-cord, speaker wire, shooting wire, dbl hookup, rainbow cable, ribbon cable) | Striker Cat | Home Built | 6 | October 15th 04 08:51 PM |
rudder cable question | Bob Loer | Home Built | 7 | November 26th 03 08:34 AM |
Where Can I Find Good P-Lead Cable | Larry Smith | Home Built | 3 | November 7th 03 11:43 PM |
Rudder cable - was The Little Wheel in Back | BD5ER | Home Built | 9 | September 11th 03 04:14 PM |
