2 Engines - 1 Prop...ME Rating?
Old January 16th 05, 05:14 AM
Andy Asberry
Default 2 Engines - 1 Prop...ME Rating?
I've Googled for everything I can find on 2 engines driving 1 prop.
There are several military and civilian examples. Nowhere did I see
that a ME rating was required of the pilot. I'm familiar with ME
Centerline thrust.
Cites, observations and comments please.
Old January 16th 05, 03:10 PM
Vaughn
"Andy Asberry" wrote in message
Centerline thrust.
It is very simple. Airplanes are classified as single-engine or
multi-engine. The classification says nothing about number of props.
You may make the argument that a redundant "engine package" containing two
engine blocks but only one set of engine controls for the pilot to manage
actually constitutes a single engine, but I would want to have that ruling from
the FAA in advance.
Vaughn
Old January 16th 05, 03:20 PM
Peter Dohm
"karel" wrote in message
Centerline thrust.
if memory serves, even a Cessna Skymaster
can be flown on an SEP license
because there's no issues with assymetric thrust
so there shouldn't be any problem in your case
KA
If my memory serves, the C-337 does require a
multi rating. However, it can be a multi rating
with a Centerline Thrust limitation; and that would
be the case if the rating was obtained in a C-337.
The limitation on privileges could later be removed
with further training and a proficiency check in a
"normal" twin...
I tend to think, as did an earlier poster, that a
fixed wing aircraft with two engines with a single
prop might be thought of as simple redundancy
(similar to dual fuel pumps) until the configuration
achieves some popularity--whether current or
anticipated.
However, remember that this is a very popular
(although expensive) configuration in helicopters.
I call to the local FSDO and/or a visit to the
next FAA Safety Seminar in your area would
be a *very* good idea!
Peter
Old January 16th 05, 03:34 PM
Peter Dohm
"Vaughn" wrote in message
Centerline thrust.
containing two
from
the FAA in advance.
Vaughn
Well and succinctly stated!
Peter
Old January 16th 05, 04:41 PM
UltraJohn
containing two
from the FAA in advance.
Vaughn
Which brings me to my question!
How 'bout a single turbine driving two props (preferable counter rotating)?
John
Old January 16th 05, 06:09 PM
On Sun, 16 Jan 2005 08:17:14 -0800, RR wrote:
On Sun, 16 Jan 2005 10:20:36 -0500, "Peter Dohm"
:If my memory serves, the C-337 does require a
:multi rating. However, it can be a multi rating
:with a Centerline Thrust limitation; and that would
:be the case if the rating was obtained in a C-337.
And there's something tickling at my memory that says you don't need a
ME rating to fly an experimental multi engine airplane. I'm probably
wrong about this, but I think there was a thread in RAH about it a
couple of years ago.
Actually, there was a subtle regulation change introduced at the same time as
the Sport Pilot stuff. Formerly, you didn't need a multi rating (or floatplane
rating, rotorcraft rating, etc.) to fly an experimental aircraft. With the
regulation change, you are required to have the appropriate rating if you carry
passengers.
As far as how the FAA would view the two-engines-and-one-prop engine, Soloy
developed a "Dual Pac" powerplant for the Cessna Caravan. It's two PT-6s
driving a single propeller. One of the main purposes was to allow the Cessna to
be used in the kinds of passenger-carrying operations that cannot be performed
with a single-engine aircraft. The Soloy literature refers to it as a
twin-engine aircraft, and I suspect the FAA does as well:
http://www.soloy.com/Resources/misctext/pathbook.pdf
It would certainly need a definitive FAA ruling. I suspect the ruling would
depend on what pilot actions are required in the event one of the two engines
failed. The Skymaster has had problems with pilots *recognizing* that an engine
has quit... trying take off when the rear engine has quit on the taxi out, etc.
The FAA might institute a new multi-engine rating just to ensure pilots received
specific system training.
Old January 16th 05, 07:41 PM
Jim Carriere
Another administrative option for the feds might be an SFAR for each
type of aircraft.
For example, the R22 helicopter is perceived to have uniquely
challenging handling in the event of an engine failure. Pilots of
that aircraft are specially required to have a certain amount of
extra training. This extra training is not required for any other
helicopters. It is a subtley different concept from a type rating,
but when you think about it quite similar.
Back to 2 engines 1 prop, if there are only two or three such unique
designs in service, this solution can properly address the issues.
PS-
Maybe I shouldn't judge, but takeing off in a Skymaster with a dead
rear engine is like an inadvertent gear up landing. Everybody makes
mistakes, but COME ON!
Old January 16th 05, 11:17 PM
Andy Asberry
On Sun, 16 Jan 2005 16:41:17 GMT, UltraJohn
containing two
Vaughn
John
History does repeat itself! Discussion moved in exactly this direction
three years ago.
The answer: Perfectly acceptable as long as it is a pusher design,
front elevator and rear rudder.
Answer provided by Orv and Wilbur.
Old January 17th 05, 03:16 AM
Dave
I would suspect that the two engines would be classified as an engine
assembly and would not be considered as a multi-engine airplane.
Dave
containing two
Vaughn
John
three years ago.
Old January 17th 05, 06:11 AM
Jim Carriere
three years ago.
Two of everything (wing, rudder, elevator, prop), except for pilot
and engine
Plus you got right on topic, the Wrights were homebuilders after all.
Immediate NSI Prop AD Robert Schieck Home Built 0 October 27th 04 08:56 PM
Book Review: Converting Auto Engines for Experimental Aircraft , Finch Paul Home Built 0 October 18th 04 10:14 PM
Ivo Prop on O-320 Dave S Home Built 14 October 15th 04 03:04 AM
IVO props... comments.. Dave S Home Built 16 December 6th 03 11:43 PM
Metal Prop vs. Wood Prop Larry Smith Home Built 21 September 26th 03 07:45 PM
